586,051 active members*
3,674 visitors online*
Results 1 to 8 of 8
    Apr 2013
    110
    MK3/9 new firmware + ExtOut board
    I own an MK3 / 9 Controller; after updating the firmware for the new TNG v.2 the ExtOut board with relay at each new switch-on has all the active outputs, which did not happen with the old firmware used with CNCUSB. I think it is a peculiarity / bug of the new firmware as the outputs are activated even if the software is closed (therefore with the controller only turning on). At the moment I have no device connected to the relays and with the M64 command I can disable them but the fact that they are activated at power on could be dangerous when I connect accessories to the outputs.
    My ExtOut card is the PoExtBusRe of Polabs very similar to that of Planet.
    Mar 2017
    1312
    Re: MK3/9 new firmware + ExtOut board
    ExtOut keeps state with H1 when software is turned off. But after controller power on sequence it should be reset. I will fix this.
    You can try H2 which does not keep state.
    Apr 2013
    110
    With H2 I don't solve ... for now I haven't connected anything to the relays ... I'll wait for your solution.
    Mar 2017
    1312
    Then I did not understand your problem. Only Ext port of H1 keeps state. If you send data to H2 port then it is send only once and thats it. When controller is powered it does not send anything on H2 port, only on H1.
    Apr 2013
    110
    In my opinion the TNG configuration does not change the behavior of MK3 at power up. Both using H1 and using H2, when I turn on the controller (both closed TNG and open TNG) the ExtOut outputs are all active; for this reason I thought it was a firmware problem.
    Mar 2017
    1312
    Do you also power cycle relay board? Because it has its own memory and persists state unless it gets different command.
    Apr 2013
    110
    Yes, I turn everything on with the same button. Do I have to try a different sequence?
    This behavior did not occur with the old firmware. tomorrow I will try to restore the controller to V1 to verify.
    Apr 2013
    110
    I managed to restore the firmware of my MK3 / 9 to V.1 and confirm what was stated above. With Firmware V.1 when the controller is switched on (and additional cards) the ExtOut relays remain deactivated.
    While, after updating to Firmware V. 2 again, the ExtOut relays are activated at power-up.
  1. ATC-firmware for M24-5 board - looking for
    By keesfrees in forum Multicam Machines
    Last Post: 04-28-2015, 10:17 PM
  2. pluto firmware
    By visky in forum LinuxCNC (formerly EMC2)
    Last Post: 11-11-2014, 12:54 PM
  3. PDX15 Firmware
    By Jäger in forum Stepper Motors / Drives
    Last Post: 05-12-2011, 01:58 AM
  4. New PICStep firmware available
    By Garfield2 in forum CNC Machine Related Electronics
    Last Post: 12-07-2010, 06:07 AM
