586,070 active members*
3,598 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Need advice on my 24" Y axis build
Results 1 to 3 of 3
    Nov 2018
    53
    Greetings!
    Everyone has always been very helpful here.
    Its been awhile. I need to build this 24x24" y axis. Think large size 3D printer for printing clay. See photo. My base is 3/4" Melamine, I have 2 20mm linear slides with 4 Bearing blocks, I will run a Small Nema 23 with 22 tooth Pulleys. I have on order HTD3M 15mm wide belt.
    My rails don't have mounting holes.
    The Bearing slides have 4 6mm mounting holes. I need to have springs, so I can Tram the bed.
    So, I was going to run a homemade bearing idler on one side and the Nema 23 with 22 tooth pulley on the other.
    I would appreciate any thought?
    I have some separate parts I'm working on I will discuss in other posts.
    Thanks!!!
    Max
    Apr 2004
    5737
    Re: Need advice on my 24" Y axis build
    Quote Originally Posted by disneytoy2 View Post
    Greetings!
    [You're just building the Y axis? What about X and Z? Is your plan to avoid using screws or R&P by using long belts to move the stage? ]
    [How are you planning to fasten them down?]
    [Where would the springs go, and how would they help with tramming?]
    [That's for tensioning the belt? Have you figured out a mechanism to move it back and forth?]
    Thanks!!!
    Max
    [It would be easier to help with this if everything was in the same thread. Are you building your own clay extruder, or buying one prefabricated?]
    Andrew Werby
    Website
    Nov 2018
    53
    Quote Originally Posted by awerby View Post
    This is an ongoing project. There are several old threads on my build. This is Custom. the other parts are 2-meter Z and X axis. This is an add on to make it Cartesian for testing.
    Just wanted some thoughts on a Y axis approach. I have a couple days until my belt is in, so I'm trying to tie everything together.
    The actual clay extruder is already built Nema 23 with a 20:1 Worm reducer.
    Max
  1. Finished 3-Axis CNC build, benchmarking advice?
    By Agebot in forum DIY CNC Router Table Machines
    Last Post: 04-30-2018, 12:47 PM
  2. Replies: 5
    Last Post: 02-23-2018, 03:23 AM
  3. 2nd Build, 50"x110" Steel Base, Aluminum Gantry, possible 4th axis
    By bob83 in forum DIY CNC Router Table Machines
    Last Post: 04-18-2017, 07:45 PM
  4. 5' x 12' x 16" 5 Axis Router Build
    By ScottDamman in forum DIY CNC Router Table Machines
    Last Post: 02-29-2016, 08:46 PM
  5. First build: 5-axis. Could use some advice!
    By giz in forum CNC Wood Router Project Log
    Last Post: 02-13-2016, 04:59 PM
