586,036 active members*
3,540 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How to set the origin at the corner of the stock?
    Apr 2010
    24
    It's been about 10 years since I've used MasterCam.
    I'm trying to create a machine origin at the corner of the stock and it's kicking my A$$!
    Last software I used was CamWorks, no problem, pick the corner.
    I'm wanting to use the lower left corner for XYZ zero. This must be a common practice but it's like a secret everywhere I look:
    Attachment 430664
    Apr 2019
    58
    Re: How to set the origin at the corner of the stock?
    Go to planes, then selwct new plane, in bottomt left corner.
    And you can move origin, place near you want and select z to move down .
    Tomorow i can make movie and send to viber or whatsapp
    +37060022992
    Išsi?sta naudojantis SM-G960F Tapatalk 4 Lt
    Apr 2010
    24
    Thanks for the reply. I ended up drawing a rectangle the size of the stock, at the bottom of the stock, creating a plane for that op, and locating the WCS on the corner, pretty much like you suggested.
    Steve
    Dec 2008
    3109
    in the stock tab....
    centre top is set as default where the co-ord XYZ points to...
    try L-clicking on a corner of the diagram (to move the stock origin )
    PS.... this is how to place the stock, not how to move the WCS.
  1. Replies: 3
    Last Post: 06-17-2016, 04:55 PM
  2. Replies: 1
    Last Post: 10-24-2014, 02:21 PM
  3. HOW TO SET THE MACHINE ORIGIN TO 0,0,0 IN THE SW CORNER
    By TheNigerian in forum Machines running Mach Software
    Last Post: 06-08-2011, 12:14 PM
  4. Radius on the corner of square stock
    By ErnieD in forum MetalWork Discussion
    Last Post: 03-31-2008, 03:35 AM
  5. Stock Origin
    By stang5197 in forum Mastercam
    Last Post: 03-13-2007, 05:36 PM
