586,069 active members*
3,361 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > need help for Connect the machine to the laptop
    Nov 2019
    Hello evryone
    I have a problem identifying the machine cnc3018 with cable for the laptop .
    When I connect the machine cable to the laptop. Windows does not recognize the machine. This message appears
    (( look at the picture ))
    Windows Message
    https://1.top4top.net/p_1402cvzj41.png
    Note . that when i run the machine with Offline remot operates without problems ..
    The cable also has no problems
    please help
    Picture of the control board
    https://2.top4top.net/p_14026st1s1.png
    Jan 2007
    626
    Re: need help for Connect the machine to the laptop
    Looks like you need to find the USB driver and install it. Nothing in the documentation that mentions that?
    A quick google bought up a post mentioning the CH340 driver. Ring a bell?
    I had set up a similar 3018 machine not too long ago and that definitely looks like you are missing a CH340 driver, I would recommend checking out Techdiy's video on the 3018 cnc:
    https://youtu.be/hB4Cvbtu-lA?t=661
    He goes through a concise rundown of all the necessary steps.
    Mar 2007
    2083
    After looking at the photo of the board I think the board is based on the Arduino nano
    The circuit diagram of the original nano uses the FT232 USB to RS232 converter IC
    http://www.ba0sh1.com/wp-content/upl...noNano-3.3.png
    FT232 driver
    https://www.ftdichip.com/Products/ICs/FT232R.htm
    clones of the Arduino found on line use the CH340 which needs its own driver to be installed on the PC
    see
    https://learn.sparkfun.com/tutorials...40-drivers/all
    Have a look at the part number on 16 pin IC near the USB connector to see if they have used
    the CH340 or FT232R
    John
  1. Need Hellp with Okuma And Gibbscam(Load monittor)
    By Motiejunas in forum GibbsCAM
    Last Post: 03-27-2018, 06:08 PM
  2. Need Hellp HAAS VF2 SS 2008 wont start
    By haasab in forum Haas Mills
    Last Post: 08-02-2013, 05:23 AM
  3. power supply hellp
    By mrendu43 in forum Stepper Motors / Drives
    Last Post: 11-17-2012, 01:37 AM
  4. Hellp
    By kalicas in forum Uncategorised CAM Discussion
    Last Post: 04-06-2007, 06:00 PM
