586,061 active members*
4,358 visitors online*
    Oct 2019
    Multi setup question
    I run a multi set up Cincinnati in the aerospace field I have a couple of questions #1 How do I set up the sequence to run the setups in a sequence? #2 When I'm doing an m-19 the spindle becomes fixed and S that gives coordinates for the spindle orientation. We keep having to take our right angle head apart and adjust it is there a way to offset the "s" to alter the spindle orientation?
    Oct 2019
    Can anybody help
    Jun 2007
    84
    Re: Multi setup question
    M19 Sxxx should orient to whatever angle (xxx) you want.
