586,072 active members*
4,619 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Why can't I use one pass here?
    Sep 2019
    Question Why can't I use one pass here?
    the part is ~.53" and I'm using a 1.0" bull end mill (r=.0315) but master cam tells me it can't do one pass because its not big enough?
    Any clues would be good thanks!
    ETA: the file is attached, as well as a picture of the issue
    Dec 2008
    3109
    Re: Why can't I use one pass here?
    Turn on "Auto Angle" ... or set "Rough Angle" to 90° or 270° to machine the thinner section
    Sep 2019
    omagosh, thank you. The instructor gave us hard limit on our verify time, and you just saved me 10 seconds, and gave me the finish I want
  1. Bad cut on second pass
    By L0UIE in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-31-2017, 01:11 PM
  2. To buy or pass?
    By A1CNC in forum Fadal
    Last Post: 08-19-2015, 12:45 PM
  3. Pass Through?
    By Jtron5 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-09-2011, 09:45 PM
  4. Step over 2nd/3rd pass
    By Sjotime in forum DIY CNC Router Table Machines
    Last Post: 12-09-2010, 07:30 AM
  5. Bad pass
    By ozstockman in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 01-04-2010, 08:32 AM
