586,104 active members*
3,377 visitors online*
    Feb 2005
    117
    M codes not working
    I have written a simple move program in note pad with the M30 command at the end.
    Saved it as a *.tap file .
    I load the program into Mach3 it comes up on the screen without the M30 command.
    I go back and edit the program and find the M30 command as the last line of the program.
    I run the program and it does not automatically rewind.
    Am I missing something in the setup of Mach?
    Oct 2005
    1145
    Re: M codes not working
    Add an empty line AFTER teh M30 or a % .
    (;-) TP
    15362
    Quote Originally Posted by johnd View Post
    As vmax549 has said add a % at the bottom and top of your program
    Mactec54
    Feb 2005
    117
    Thank you
  1. G codes and M codes for Mazak Quick Turn T-2
    By sauli in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-23-2011, 05:22 PM
  2. Need Help - Programs working for Years they all get error codes
    By richlandrick in forum Mach Software (ArtSoft software)
    Last Post: 05-27-2010, 04:07 AM
  3. Need full list of G CODES AND M CODES FOR FANUC 21I
    By SonnyTees.com in forum G-Code Programing
    Last Post: 02-23-2010, 05:27 PM
  4. Replies: 3
    Last Post: 12-08-2009, 02:28 AM
  5. M-codes and G-codes 4 Matsuura ES-1000V
    By maximusek in forum G-Code Programing
    Last Post: 11-27-2007, 01:41 PM
