586,067 active members*
5,106 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Autodesk Post Processors > Hartford Pro1000a with Mitsubishi Meldas M64 post processor
    Jan 2013
    Hello Gentlemen,
    I have recently installed a 2005 Hartford Pro 1000a VMC with a Mitsubishi Meldas M64 controller and I need a post processor for it. I've spoken with Hartford and their Australian distributor, neither can help.
    If someone has one fantastic, if not I would be equally grateful if you could point me in the direction of someone who could write it for me.
    Thank you in advance for your assistance.
    Kind regards,
    Jason
    Apr 2015
    327
    Re: Hartford Pro1000a with Mitsubishi Meldas M64 post processor
    Quote Originally Posted by AdminCrew View Post
    Hello Gentlemen,
    Kind regards,
    Jason
    Hello,
    im developing postprocessors for a Autodesk HSM. If you still want you can contact me.
    You can check some my jobs there.
    https://www.youtube.com/channel/UCqRZCqB5RpJq37ZJmQ5y-TQ?view_as=subscriber
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Jun 2008
    1838
    Hello Gentlemen,
    Kind regards,
    Jason
    Hi Jason
    There is a Post Processor that is specific to the Mitsubishi Meldas control for Fusion 360,
    I have attached it in a Zip file for you, just open the Zip file and copy and paste the Post
    Processor .cps file into your "Personal Post Library" and use it from there.
    There are two other Post Processors for Mitsubishi, one for Lathe and another for Milling, if
    you want to try the other Milling one then here is the link to the Online Post Processor Library
    https://cam.autodesk.com/hsmposts?
    Hope that helps some
    Regards
    Rob
