586,075 active members*
4,000 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Protect the Z probe area from accidental contact
Results 1 to 2 of 2
    Sep 2009
    88
    A new build cnc router (3100 1600mm) with a Nc300 controller and Delta asda servo drives, and now bought and installed a Z probe https://m.ebay.ie/itm/High-Precision-Mach3-sensor-setting-CNC-Router-Z-Axis-probe-tool-touch-auto-tool-/113697047671?_mwBanner=1&_rdt=1
    And it works. It is outside the geber working area on Y (dibond boards 3000mm long, while the probe is at 3090 on Y). My concern is that while jogging the machine I will hit accidentally the probe and damage it.
    The probes runs through a macro routine.
    The Y 1st positive soft limit is at 3100 so the probe can be accessed - if I set the limit to 3000mm, the macro will return an soft limit error.
    So my question is if anyone knows how to set a soft limit such that the jogging caanot access the probe area, but when the macro is loaded the soft limit is temporarily suspended. At the end of the macro another command will engage again the limit.
    To further provide the context, besides the 1st positive sortware limit there is the 2nd positive limit, so my guess is that this could be somehow used for this purposes but I am not aware of any command that would do the job.
    Any direction of exploring would be highly considered.
    Thanks you
    Mrius
    Jun 2015
    4154
    Re: Protect the Z probe area from accidental contact
    hy / if 55$ is the correct price, i would crash it without worries
    i have tool-change macros that avoid the setter-zone, and also other macros that check if z_clearance is lower than probe phisical height ... but only for okuma
    also, some setters have safety protection, stopping the machine when they detect accidentaly movement / kindly
  1. would like to contact someone in the memphis, tenn. or north miss area
    By Aaron B in forum DIY CNC Router Table Machines
    Last Post: 03-08-2016, 11:41 PM
  2. TP-100 contact probe compatability with ALLin1DC controller
    By Scorpion2 in forum Centroid CNC Control Products
    Last Post: 04-07-2015, 04:04 AM
  3. Looking for a guy in the DFW area, lost his contact info...
    By SatanKlawz in forum Mentors & Apprentice Locator
    Last Post: 02-05-2015, 07:45 PM
  4. contact probe build
    By Valen in forum Calibration / Measurement
    Last Post: 12-28-2010, 11:17 PM
  5. DIY Non contact probe?
    By Jayson in forum Digitizing and Laser Digitizing
    Last Post: 03-01-2006, 01:55 PM
