pls, how to check if there are free M codes ?
hello, pls, how to check if there are free M codes, on genos l3000 ?
should i be looking for something inside the electrical cabinet, on the controller, etc ? kindly
Code:
ccdrps-pv1.35 - 5/10 - <W01><O01>< L3000-EE><P574205>
===========================[ NC-SPEC CODE No.1 ]==============================
1100-0100-4101-0000-14C0-0F18-1300-1043
0001-9DD2-2980-0100-0111-6000-1041-0002
SLANT-Y AXIS - ONE TOUCH IGF ADVo EXTERNAL MEASURE - TOOL CENTER CTRL -
Y AXIS BY CT-Z - TAPE DATA IN/OUT o MEASURE RS232C - Hi-Cut Pro o
- FD IN/OUT(IBM) - CEJ MATIC - SUPER-NURBS Hi. -
Y-AXIS BARRIER - WITHOUT MS-DOS - SIZE CATCHER - NURBS -
Y HORI.BARRIER - T-SEPARATE EDIT - EX.MEASURE BCD - SUPER Hi-NC -
B-AXIS 0.001‹ - DNC-C ETHERNET - T-SETTER R/L COM - SUPER-NURBS Rac. -
B-AXIS 1‹PITCH - P-200 SPEC o - TOOL-ID -
B-AXIS CONTROL - FL-net - - Inverse Time Feed-
ATC - BUFFER 160M - TOUCH SETTER o ST. REST ZB -
1CAM-ATC - BUFFER 320M - 2ND SP MEASURE - ST. REST MID -
2CAM-ATC - BUFFER 640M - TOUCH SETTER AUTO- ST. REST ZC -
EXT.ATC HOME POS - BUFFER 1280M - TOUCH SENSOR - -
VTM MACHINE - NO-SSU-RD o C ZERO OFFSET - ST.R TOW-A.B -
NEW MG.PANEL - FDD3.5INCH EDIT - Y GAUGING - ST.R TOW-A.AUTO -
PANEL OLD TYPE - EDIT INTERLOCK - OPTICAL SENSOR - ST.R TOW-A.JOG -
Y-AXIS TRQUE LIM.- EDIT INTERLOCK C - MEASU.DATA PRT. - ST. REST TOW-A. -
HI-G CONTROL o PROGRAM SELECT - - CE MARKING o
PFC‡U - MG TOOL READY - - -
B-AXIS COMP. - COMMON VAR. NAME - - NC DOOR -
X-AXIS COMP. - HOME POSITION B - - SPEC. SELECT -
WK.CORDINATE 10 - WARMING UP - - R SPEC -
WK.CORDINATE 50 - MACHINE LOCK SP. - - -
TOOL OFFSET 500 - G00 LINEAR FEED - ABSO SCALE CA - THERMAL COMP. L2 o
TOOL LIFE WARN. - A/B SYNC. MOTION - o THERMAL COMP. L1 -
NC TURRET o PLANE CONVERSION o TURRET POS.COMP. o NC MASTER -
OTC TURRET - PROFILE GENERAT. o TOOL OFFSET 64 - S-LINK NC TEST -
CAM TURRET - CONTOUR CUTTING. - TOOL OFFSET 96 - S-LINK SP TEST -
MANY CHIPS TOOL - B-AXIS INTERPOL. - TOOL LIFE MNGMNT o OH -
ABSO SCALE TA - SYNCHRO.TAPPING o TOOL OFFSET 200 - NEW OPERAT.PANEL o
B-AXIS TURRET - FLAT TURNING - TOOL WEAR COMP. o NO SERVO -
HEAVY TOOLING o HELICAL CUTTING - TOOL OFFSET SYS. - PLC/SFC PROGRAM -
DOUBLE TOOLING - SLANT CUTTING - TOOL OFFSET 800 - PLC -
LT MACHINE - HOME POSITION - - NC ROBOT -
SUB SPINDLE - SPINDLE SYNC.TAP - I/M SWICTH o NC LOADER -
PARALLEL 2 SPNDL - TOOL RETRACTION - SCRIPT FUNCTION - SYSTEM STAT.DISP -
PICK OFF UNIT - SPIN. FLUCTUATE o WINDOWS OPERATION- OH LOGO CHANGE -
VERTICAL MACHINE - NC TORQUE LIMIT. o CYCLE TIME CAL. o C-AXIS COMP. 2 -
LAW-V MACHINE - THREAD OVERRIDE - CYCLE TIME REDUC - F CONVERT -
ACC MACHINE - GM CODE MCRO - CYCLE TIME R.NEW o LOST MOTION CMP. -
B-TURRET SUB SP. - CENTER COMP. - NO LOAD DETECT o PLR2 LOW SEQUENCE-
MULTIPLE MACHINE o LAP4 o NC WORK COUNTER o PROG. TAIL STOCK -
B-TURRET M-AXIS - NOSE-R 2B o WORK CNT.SPECIAL - SIMPLE TOW-ALONG -
M-AXIS NO C-AX. - USER TASK 2 o NC WORK MONITOR o PG. TAIL STOCK B -
T/M AXIS SW. - EXP.AUTO CHAMF o CYCLE TIME CHECK o AUTO TAIL STOCK -
L TOOL INDEX - THREAD PNT.OFFST - LOAD MONITOR o TAIL STOCK CLUMP -
- THREAD FEED HOLD - LOAD MONITOR W - NC TAIL STOCK o
MULTI-MAGAZINE - ARC THREAD CUT. - MAC MAN COMM. - NC TAIL STOCK TRQo
SYNCHRO. REVERSE - COMMON VAR. 1000 - MAC MAN o MANY CHIPS 12 -
2 SADDLE MACHINE - ONE TOUCH IGF - DNC-T1 o SPINDLE ORIENT. o
MIRROR IMAGE - IGF - DNC-T2 - MANY CHIPS 4 -
Z-W OVER LAP - IGF CONVERT - DNC-T3 - CB-AX. WO MB-AX. -
CAM MACHINE - IGF DATA TRANS - DNC-T4 - C SYNC. CONTROL -
NEW W-DATA - ONE-TOUCH S/SHEET- DNC-P1 - M-AXIS ORIENT. o
SUB MAGAZINE - COL.AVOID.SYSTEM - DNC-P2 - L MULTIPLE MACHIN-
H1 TURRET - PROGRAMING HELP o DNC-P3 - R MULTIPLE MACHIN-
FLAT BED - HELP o DNC-P4 - HOB CUTTING -
SERVO LINK NC o STN L.C.D MONO. - DNC-A - SPINDLE MAX IL. o
- E100 SPEC. - DNC-B - SP-HEAD IL. -
0 OFFSET DETECT - 3D. ANIMATION o DNC-C1 - PARTS CA. IL. -
- ACP EXPANSION - DNC-C2 - 1S PARTS CA. IL. -
SERVO LINK SPNDL o ANIMATION o DNC-C3 - ZA-W AXIS IL. -
SPINDLE ANALOG - S10 SPEC. - DNC-DT - XB-W AXIS IL. -
SPINDLE I/O - U100/U10 SPEC. - SMPL.REMOTE DIAG - TURRET ZA-W IL. -
- OAC MESSAGE - DNC-RT - TAIL-ST.REST IL. -
ccdrps-pv1.35 - 6/10 - <W01><O01>< L3000-EE><P574205>
===========================[ NC-B SPEC CODE No.1 ]============================
0040-A300-0000-C010-3005-5100-0000-0000
0000-0380-0000-0000-A000-6D00-A000-0000
COORDINATE CONV. - ATTACHMENT - A-TRT MID. POS. - CAM-AXIS ICB -
WK.CORDINATE 100 - ATTACHMENT SWIVEL- B-TRT MID. POS. - CAM LE. LESS -
TOOL OFFSET 999 - MLT MAG. TYPE-C - C-TRT MID. POS. - -
CORDINATE CAL - VTR - CAS HYDRAULIC TRT- -
PROGRAM MESSAGE o LONG BORING BAR B- - -
3-D CO. CONV. - 3-D CO. CONV. 2 - LATHE X-RADIUS - -
PROF.GENE.HELI. - 3-D INDEX - OP. BUFFER EXPAND- -
PREMIUM THREAD - L TOOL INDEX SP. - MULTI TOOL - EtherNet/IP -
NC TST HI PRECISE- MEAS.DATA COMM.SP- HI-SPEED RESTART - -
NC TST POLS LOW - 3 AXIS MEASURE - L-G IGF LINK - -
NC TST CHECK LESS- M-AXIS MEASURE - BLOCK SKIP MULT. - -
TST 1ST-SP ATT. - M-AXIS INTERPOL. - M-GUIDANCE 2 - -
W AXIS CUTTING - BLUM HYBRID SEN. - T-GUIDANCE(MAIN) - -
- - T-GUIDANCE(SUB) - -
NC TST 1st INCH o - - -
NC TST INCH o - - -
APC - TOUCH SETTER2 - ABCO SCALE YSB - -
NC UNLOADER - STROKE LIMIT RLS - ABSO SCALE YSC - -
WORK SUPPORT - RIGID TOUCH SETR - ABSO SCALE XC - -
MULT.U MATRIX MG - Y-MODE TOUCH SETR- ABSO SCALE ZC - -
L TOOL IDX. SEL - TL BRAK. DETECT. - - -
MLT MAG. TYPE-B - AE SENSOR - - -
ATC.EX.HP - BLUM SENSOR - - -
POT TOOL TABLE - STROKE DIVIDE - - -
MG-AXIS ATC - PLC CROSS RAIL - B-TRT Y-AXIS - STATUS LOGGER -
C-AXIS 1POINT - NC CROSS RAIL - - STATUS MONITOR -
RT-AXIS ATC - HP CROSS RAIL - ZA-ZC AXIS IL - RETRACT(ST.MON.) -
- - - ADD. SENSOR -
TR. ATC TYPE-A - - 3 SADDLE MACHINE - -
TR. ATC TYPE-B - - C-TRT M-AXIS - GATHER AGING o
TR. ATC TYPE-C - - C-TRT SUB SPNDLE - -
TURRET ATC - - C-TRT Y-AXIS - MACHINE DIAG. o
CUSTOM-API - TOOL DIRECTION - SA AXIS TANDEM - 2M1L ONE SIDE CUT-
OSP-API - TOOL DIR COMP. - SB AXIS TANDEM - -
USER TASK 3 - TCPC MACHINE CO. - SPINDLE ACCEL SET- -
THiNC ALARM - TCPC CUT POINT - SPINDLE ROT. 0.1 - -
M-INTELLIGENCE - TCPC SUB SPINDLE - STEP CUTTING FEED- -
M-SPN. FLUCTUATE - TCPC LATHE TURN. - C-AXIS CLAMP AUT.- -
L-GUIDANCE - B/C TURRET TRIC - TOOL GROOVE PROC.- -
M-GUIDANCE - SUPER PROF. GENE.- SP.COL. DETECTIONo -
USE TOOL DISP. o AXIS ACTIVE STOP o CE MARKING STOP o EASY OPERAT PANELo
MACHINING MODE o M-AX LIFE COUNT - MFU o MULT OPERAT PANEL-
NOSE-R DIR CHG - 0.1u TB/MB AX. SP- GEOMETRIC COMP. - L TOOL MAC INFORMo
INTERRUPT PROGRAM- STRAIGHT. COMP. - GEOMETRIC MES. - EOP ANM SCALE-UP o
INTERRUPT PROG2 - VAR. LOST MOTION o - 19 INCH EXTEND -
BASE OP. SCREEN o SERVO NAVI L - - ECO SUITE o
TOOL MAC INFORM. - RPD FD SPEED SET o M-AXIS TORQ. SKIP- OSP SUITE o
OFFSET BASE FIX o TIME CONST SELECT- TURNING CUT - BASEZERO Z V.MEAS-
SERVO ADJUST SP - WORK WEIGHT SET o SELF ST.R 1 - POWER METER -
TOOL LIFE NOT.SP - Y-AX MANUAL FEED - SELF ST.R 2 - TH.COMP.OILCON -
WORK ROUGH - C-AXIS MANUAL CO.o SELF ST.R 3 - -
ST.REST BARRIER - C-AXIS TORQ. SKIP- SELF ST.R 1 REL. - -
WORK POSITION 30 - HOME POSITION C - SELF ST.R 2 REL. - -
NO HIGH LOW TH. - AT ROTATION COMP - SELF ST.R 3 REL. - -
TORQUE WATCH o LONG BORING BAR - - -
TAILSTOCK SP.LOW - TOOL BASE - - -
TOOL LIFE NOTICE - SYNC.CONTROL ZA - BELT SLIP CHECK - MAC. TIME SHORT. -
GOT-HMI - SYNC.CONTROL XA - M BELT SLIP CHECK- -
MEASU.COMP.CLEAR - - - -
ALARM MESSAGE - - - -
OTHER.SYS.WATCH - SDF SEPARATE NC o GEN. OL. DETECT - -
CON BACK SP - SDF SEPARATE SP o NO LOAD DET. EXT - SPIN. OUT. MON. o
0.1u T/M AXIS SP.- SDF SEPARATE PLC - LOAD MONITOR EXT - SUITE w/o WIDGET -
LOST MOTION CMP. - FEED AXIS RETRACT- C-AX NOTCH FILTER- REMAI.TIME DISP. o
ccdrps-pv1.35 - 7/10 - <W01><O01>< L3000-EE><P574205>
===========================[ PLC-SPEC CODE No.1 ]=============================
0200-0210-0000-0100-0100-0012-0001-0100
0000-0020-4004-0012-0000-0000-1040-0000
ST. REST FIX - HIGH COOLANT - OVERRIDE SPECIAL - L TOOL INDEX SP -
ST. REST MID - B-TURRET 1MMTR - LOAD MONITOR o TL EXST COMF.REV.-
ST. REST LOW-T - A-COOLANT 1MMTR - SAFETY TAPE SW - -
ST. REST REL. - COOLANT H/L SP. - NC MASTER - FL-net -
ST. REST OPEN - CLNT LEVEL CHECK - CYCLE TIME RE.NEWo -
ST. REST CLOSE - CLNT FLOW CHECK - LAW-F L-MACHINE - -
ST. REST TOW-A - COOLANT L/M CHG. - PNL.POSIT. FRONT - -
ST. REST GR.COMF - CLNT.THRU.SPNDL. - T CONST SWITCH - -
CENTER WORK o M-AXIS ORIENT. o DNC-B - B-AXIS TURRET -
TAIL STOCK LIMIT - FLAT TURNING - DNC-C - B-AXIS 1‹PITCH -
TAIL-STK.IL.RLS. - B-TURRET M-AXIS - ATC TYPE G - B-AXIS 0.001‹ -
PROG. TAIL STOCK - B-AXIS POS LOMP - W-AXIS OVERLAP - TURRET TYPE-H1 -
SIMPLE TOW-ALONG - ATC TYPE H - ST.R AUTO TOW-A B- TURRET TYPE-H2 -
TAIL STK.RT.INCH - CAM AXIS LUB. - THREAD OVERRIDE - TR.PNDLM.CNTRL. -
ST.R AUTO TOW-A. - M-AXIS OIL MIST - IND.CHK1 NO CHECK- L TOOL INDEX -
ST. R. ENABLE SW - M-SP. OILCOOLER - PROG. TAIL STK. B- L TOOL THD. CLMP -
CHUCK GRASP COMF - TOUCH SETTER o WARMING UP - NO CEIL 2 -
CHUCK IL. RLS. - TOUCH SET. SLIDE - WORK CNT.SPECIAL - NO CEIL 3 -
CHUCK. MISS 1 SP - TOUCH SET. COVER - CHIP CNVYR CHECK o WORK STOCKER -
CHUCK. MISS 2 SP - TOUCH SET. MOTOR - THRU&MEASURE AIR - WORK STOCKER2 -
CHUCK H/L 1 SP. - TL BRAK. DETECT. - DRAIN PUMP - VERTICAL SW. LO. -
CHUCK H/L 2 SP. - WORK EJECTOR - SP AIR PURGE DET - T.CLMP OUTPUT HLD-
INDEX CHK 45 1SP - WORK EJ.AD CONF - AIR PRES.DETECT - B-PANEL o
INDEX CHK 90 1SP - WORK EJ.RT CONF - SEQUENCER ALARM - NC DOOR -
2 CHUCK PDL. 1SP - EXTERNAL MEASURE - DUAL START - NC ROBOT -
SMW CHUCK 1 SP. - EX. MEASURE BCD - DUAL ST.DR. CLS. - OR5 -
FR.DRV.CHUCK 1SP - CEJ MATIC - EDIT INTERLOCK - HYD ER DET. -
CHK GRSP SPC 1SP - TOUCH SENSOR 2SP - PROG.STOP SPECIA - SPEC SELECT -
2 CHUCK PDL. 2SP - TOUCH SENSOR - PANEL POSIT. SP - NO CE DOOR OPENLSo
SMW CHUCK 2SP - OPTICAL SENSOR - PORTABLE PH - OSP CHIP CONVERE -
FR.DRV.CHUCK 2SP - 2SP TOUCH SETTER - CE MARKING o SWING&LIMIT SWIVE-
CHK GRSP SPC 2SP - TOUCH SET. COV.LK- OIL LEVEL DETECT - OR SEFTY FENCE -
HYD. UNIT COOLER - MECHA-LOCK DOOR1 - BF/PC BIT SWITCH - A CLAMP MISS CHK -
OIL COOLER ALM-A - MECHA-LOCK DOOR2 o PARTS CATCHER - B CLAMP MISS CHK -
HYD. OIL COOLER - R.DOOR2 - PARTS CA.DOOR IL - SWING IL TYPE-A -
WITHOUT STE SW - AUTO DOOR2 - PARTS CA.AD/RT SP- SWING IL TYPE-B -
EX BRAKE RELEASE o DOOR IL. S o PARTS CA.SWING - DUAL HAND OPE. -
SAFETY RELAY - DOOR IL. D - NC TAIL STOCK o FENCE MECHA-LOCK -
POS UNIT - DOOR IL. E - CONV.DEVICE I/F - HAND OPE. I.L. -
CHUCK IL.RLS.SP - MECHA-LOCK SP. - UNLOADER I/F - LDR AXIS INTRLCK -
SPNDL OIL AIR LUB- DR.SPEED SWITCH - BAR FEEDER I/F 1 - NC LOADER -
SPNDL ORNT.ELEC. o AUTO DOOR - BAR FEEDER I/F 2 - NC LOADER TYPE-C -
SPNDL ORNT. PIN - DOOR CONTROL - B.FEEDER CHK.IL. - 2M1L -
SPNDL ORNT. BRK. - R.DOOR ONE BODY - BAR FEEDER I/F 3 - 3M1L -
1SP. LOWEST SP. - R.DOOR SIDE OPEN - BAR FEEDER I/F 4 - GANTRY LOADER -
2SP. LOWEST SP. - ROOF DOOR - BAR FEEDER I/F 5 - RECIPROCAL INTER -
1SP. OIL COOLER - PL DOOR I.L.E-D - THRU. AIRBLOW IL.- 2CARRIERS LDR -
2SP. OIL COOLER - PL DOOR I.L.E-C - CUT OFF DETECT - 3 AXIS LOADER -
- ATC TYPE A - RBT/LDR I/F B - TURNOVER DEVICE -
FLAT BED - ATC TYPE B - RBT/LDR I/F C - TRNOVR RTRCT SP. -
W-AXIS CONTROL - ATC TYPE C - RBT/LDR I/F D - TURNOVER L->R -
HYD LESS - ATC TYPE D - OGL LOADER I/F - DIREC SWITCHABLE -
W-AXIS CLAMP - MG. DOOR 2 - PROGRAM SELECT A - MULTI-MAGAZINE -
HOB CUTTING - MG.DOOR MECHA-LK - PROGRAM SELECT B - M.LOCK SP CVR. -
B-TURRET SUB SP. - MG TOOL MAN CHG - PROGRAM SELECT C - LVT SAFETY FENCE -
B-AXIS INTERPOL. - TOOL ID - FIX POT ATC - MEASURE OVER M/C -
2 SADDLE MACHINE - NC TURRET o LFS10 - FINGER CHUCK 4-1 -
MULTIPLE MACHINE o TURRET LIMIT A - LVT - FINGER CHUCK 4-2 -
OPPOSED TURRET - CAM TURRET - LAW-V - FINGER CHUCK 2-1 -
SUB SPINDLE - NC TR WITH BRAKE - 2SP-H - FINGER CHUCK 2-2 -
OPPOSED 2 SPNDL - TURRET LIMIT B - ACC MACHINE - COLLET GRSP COMF -
SLANT-Y AXIS - 1MMT CLUTCH COMF.- ATC TYPE-E - SIDE COVER I.L. -
PARALLEL 2 SPNDL - 1 MOTOR MULTI TR - ATC TYPE-F - M.LOCK SIDE CVR. -
B-AXIS TURRET - 1MMT BRAKE CR - SUB MAGAZINE - SUB PANEL -
ccdrps-pv1.35 - 8/10 - <W01><O01>< L3000-EE><P574205>
===========================[ PLC-SPEC CODE No.2 ]===========================
0100-0008-0100-0000-0000-0000-0000-0000
0000-0001-0010-0000-0000-0000-0088-0000
HP COOLANT UNIT - 1SP C BRAKE KEEP - MAN JOG FEED - -
HP COOLANT UNIT2 - 2SP C BRAKE KEEP - SP COM. UNIT 0.1 - -
HP COOLANT UNIT3 - FD.CHUCK 1 GRSP - CHIP NIPPING AVO.- -
RV. FLUSH CLNT - FD.CHUCK GRSP.CK - CAT TOOL DIR. - -
BL. SADDLE CLNT - C UNCLAMP CONF. - TABLE ROUND CONV.- -
ANOTHER TANK - 1SP A.CHUCK RSS - MG CLAMP - -
RV. FLUSH CLNT2 - 2SP A.CHUCK RSS - SETUP MODE - -
SP TAIL WORK HLD - NC ST. R. CLAMP - GEN. OL. DETECT - PREVENT TS. RT. -
SAFETY SW RST - OPTICAL SENSOR B - RIGID TURRET - SIDE SHUTTER -
DOOR DIVISION - TOUCH SET.SLD B - A-TURRET PENDULUM- TCH STTR POS RV -
FLAT DOOR IL - TOUCH SET.CROS-L - B-TURRET PENDULUM- 1SP CHK GRASP C -
FLAT 1 DOOR - TOUCH SET.CROS-R1- A-TURRET PND. SW.- 2SP CHK GRASP C -
FLAT DOOR IL SP - TOUCH SET.CROS-R2- B-TURRET PND. SW.- W-AXIS CUTTING -
FLAT DOOR MLK - TOUCH SET.SLID R - DOOR IL. SW CHECK- TOUCH SET.TRN.SLD-
R.DR.GUIDE SLIDE - TR.&MEASURE AIR - OSP CNVYR PNL.SP - DOOR I.L.E-C SP -
MAINTE DOOR - T SETTER MOTOR B - SPNDL LUBE DRAIN - SP. LATHE TOOL -
NC STEADY REST - SCHUNK CHUCK 1 SP- ACC AREA SENSOR - MCTYPE VTR-A -
ST REST AIR CLAMP- SCHUNK CHUCK 2 SP- SP VIB. SENSOR - ANGLE HEAD -
SELF ST.R 1 - CHUCK H/L B 1SP. - S-ST CHK. PDL/PB - L-NAVI GUIDANCE -
SELF ST.R 2 - P-TS UNCLAMP IL - APC SPNDL CLAMP - EASY OPERAT PANELo
SELF ST.R 3 - HP COOLANT UNIT5 - PH TYPE-B o ANG COOLANT -
SELF ST.R 1 REL. - HP COOLANT UNIT6 - C CONNECT SP - ANG AIRBLOW -
SELF ST.R 2 REL. - VTR CHUCK CTRL - PH TYPE-C - SHOWER SW -
SELF ST.R 3 REL. - 2APC SETUP CLAMP - THINC ALARM - MF UNIT o
NC TAIL WORK HLD o HAND PUSH. AIR - 2PALLET APC - ATC TYPE-P -
NC TAIL NO CHG - STOCKER INV.CTRL - STACKER CRANE I/F- ATC NO MOD RST -
NC TAIL NO PEDAL - STCK.AREA SENSOR - C AXIS GROUP SW. - DOOR WINDOW -
HYD QL NC TAIL - 3AX LDR SWING IL - PALLET CLAMP B - DRUM FILTER -
NC TAIL PRECISE - CHUCK H/L B 2SP. - 2PALLET APC I/F C- PH ENABLE SW -
NC TAIL POLS LOW - 1SP C GAIN CUT - 6PALLET APC I/F C- ATC SIDE TH.TOOL -
TAIL SLEEVE I.L - 2SP C GAIN CUT - APC DOOR - ST.REST MAN GRIP -
TAIL SLEEVE 1SP - NC UNLOADER - PALLET CLAMP C - 3 SADDLE MACHINE -
CHUCK GRASP CO.B1- SUB PNL.B ST.CHG - NEW CEMK o AIR NOZZLE SW -
CHUCK GRASP CO.B2- CENT.PARTITION - M-NAVI GUIDANCE - M-SP AIRBLOW SW -
ST. REST ZC - SP PEAK POW. CUT - SUB PNL.B BIT SW - CHIP CON SW -
NC TAIL INCHING o CE CHUCK NO CONF - ATC OIL PRES.DET - OILMIST SW -
INDEX CHK 45/90SW- ATC TYPE-Q - OIL LEVEL DET.2 - OILHOLE SW -
2SP CHK DS SENSOR- MULTI-MAG. B - VERT. MLT. PANEL - OILHOLE HIGH SW -
CHUCK GRASP CO.D1- APC FRONT DOOR2 - OPERATION DOOR - COOLANT CLOG -
CHUCK GRASP CO.D2- CHUCK/JIG CHANGE - C CLAMP CONF. - COOLANT LV CHECK -
SP. LOW. FIX. SP.- A TURRET MID. - PWR SUP R/L COM - M-SP COOLING -
C AXS BR. TRQ LMT- B TURRET MID. - EX CUT FEED OVR - THR SP COOLANT -
SKIVING CUT - C TURRET MID. - EX INT PROGRAM - X-AXIS OILMIST -
TURN.TOOL GROOVE - 2APC I/F B - SUB PANEL B - OIL SKIMMER -
1SP WIND-CHG SP - L TOOL IDX. SEL - EX NC FEED HOLD - COOLANT COOLING -
2SP WIND-CHG SP - B 2MMTR TYPE B - INSIDE M/C CNVYR - COOLANT SW -
SP BRAKE PS - C MODE C BRAKE - LIST UP MOSNIC A - WORK WASH SW -
MAN MODE C BRAKE - TAIL STOCK CLAMP - LIST UP MOSNIC B - CHIP FLUSH SW -
MANY CHIPS 12 - M-SP LUBE CHECK - HP COOLANT UNIT4 - AAC -
MANY CHIPS 8 - M-SP OIL AIR - AXIS RETRACT - M-SP CL/UC MCODE -
ATC POS INDEX RE - MA-SP. LOWEST - CROSS RAIL AUTO 7- AT MCODE -
B-AXIS 5deg PITCH- M-SP 4P INDEX - CROSS RAIL AUTO 8- AT-C INDEX 5DEG -
MANY CHIPS 4 - TOOL M-SP.MAX - CROSS RAIL AUTO 9- MAN AT TOOL CHG -
TL EXIST COMF. - C-TURRET M-AXIS - CROSS RAIL AUTO10- AAC TYPE B -
TURNING IL - CHIP BITING AV. - DOOR IL S SP - DOOR IL S SP2 -
2MOTOR TR TYPE B - Machin. Navi M-i - PENDANT IL - CONVEYER HOLD DR -
2MOTOR MULTI TR o LINEAR GUIDE CVR.- FIRE ALARM CHK - ATC TYPE M -
2MOTOR TR B - ATC CYCL TIME RE - MIST COLLECTOR - ATC SHUTTER -
TR INDEX COND W - ATC TYPE I - 0.1UM PH CHG - MATRIX TIM.RE.A -
2SP-H TR.CLMP-R - EX ATC HP - CROSS RAIL AUTO - MATRIX TIM.RE.B -
2SP-H TR.CLMP-L - ATC TYPE J - CROSS RAIL AT-C - ATC COV.TOOL -
B TURRET Y - ATC TYPE K - SP ER DET. SHARE - ATC LATHE TOOL -
C TURRET Y - TOOL RET MT CM - ABSO SCALE FILT. - ATC TYPE N -
2 MOTOR TR C - ATC TYPE L - 1SP INDEX CHK SP - ATC SENS. TOOL -
ccdrps-pv1.35 - 9/10 - <W01><O01>< L3000-EE><P574205>
===========================[ PLC-SPEC CODE No.3 ]===========================
0100-0000-2000-0000-0000-0000-0000-0000
0000-0000-0000-0000-0000-0000-0000-0000
TH./ATC AIR COM. - - - -
A L-TUR. ATC - - - -
B L-TUR. ATC - - - -
ST.R GR.COMF C - - - -
PROG TS AIR CLP - - - -
CUT STATUS MON. - - - -
SP.DIAGNOSTIC o - - -
ATC TYPE-S - - - -
ENABLE SW CHECK - - - -
BLUM TOUCH PROBE - - - -
TR BRAK. DETECT.C- - - -
HYBRID SENSOR - - - -
ST.R. MOUNT PAR. - - - -
TAIL ADVANCE 2 - - - -
PARTS CA. BELT - - - -
OIL CNLT SPECIAL - - - -
OSP suite - - - -
TURNING CUT - - - -
Work Supp.B-Tur. - - - -
NC UNLOADER B - - - -
WORK EJECT H1 - - - -
CE PARTS CA.DRIL - - - -
BALL SCREW COOL. - - - -
DATA TRA. OUT.MG - - - -
VL L-MACHINE - - - -
WORK SUPPORT SP. - - - -
HP COOLANT UNIT7 - - - -
TOOL IC - - - -
ST.R GR.COMF B - - - -
TL BRAK. DETECT.B- - - -
THRM. OIL COOLER - - - -
DOOR INCHING - - - -
CHIP CNV.INTERV. - - - -
ECO SUITE o - - -
M-AXIS INTERPOL. - - - -
M-AXIS MEASURE - - - -
M-AXIS CLAMP M - - - -
MATRIX TLS SHUT. - - - -
ATC-H MATRIX MG - - - -
C-AXIS CLAMP AUT - - - -
NC TAIL START IL - - - -
