You would requires some kind of drive that can accept a commutation signal. And use the correct commutation detectors, phased correctly, it looks like they supply these.
Also the rotor is P.M. so some kind of BLDC drive is required.
To use them in any other simpler fashion you would have to feed the three windings with three phases and make a squirel cage rotor/armature in place of the PM, but this may not be feasable.
Al.
Albert E.
