586,060 active members*
4,127 visitors online*
IndustryArena Forum > MetalWorking Machines > Turning Machines > .018 ID x .260 Deep in 360 Brass
    Feb 2008
    25
    Trying to drill this hole on a production basis (30,000) parts on a Tsugami S206 Swiss lathe. Started using jobber length twist drills because I knew I'd break a few.
    The plan is to drill .0173", then ream .0180", print calls for .0180" +/- .0004"
    Spot drilling with 1/8" spotting drill
    7500 rpm
    first peck at .001ipr, .042 deep
    succeeding pecks at .0024ipr, .010deep
    pull out to Z0.0
    feed back in to .020 short of previous depth at .01ipr
    A drill will make 0 to 20 holes. I have varied spindle speed from 5000 to 10000, 5000 was the worst. Adjusted X position by .0001 increments to fine tune the alignment ( produce the least tapered hole). It appears that the flat at the bottom of the spot drill hole from the spotting drill's chisel point is larger than the diameter of the .0173 drill. I tried a carbide drill when things appeared to be going better, but it disappeared on the first hole. Using neat cutting oil.
    Questions, thought, ideas, experience, knowledge all are welcome with appreciation!
    Make it a great day,
    Chip
    15362
    Re: .018 ID x .260 Deep in 360 Brass
    Quote Originally Posted by chipmakes View Post
    7500 rpm
    pull out to Z0.0
    Chip
    Grind or buy a carbide D-Bit it will hold a .005 point for spot drilling
    Mactec54
  1. Making Iron Heat Stamp on Brass - V Carving on brass with 20 degree V-Bit
    By kostas1 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-02-2018, 05:00 PM
  2. Deep Deep Pocketing issues
    By Dsmed in forum Tormach Personal CNC Mill
    Last Post: 01-22-2013, 06:00 AM
  3. Replies: 10
    Last Post: 01-16-2013, 06:52 AM
  4. Thread cutter Tr30x6 brass 70mm deep
    By arucas in forum CNC Tooling
    Last Post: 01-28-2011, 09:30 PM
  5. Deep-hole drilling in aluminum D5 75mm deep
    By flubber2010 in forum Drilling
    Last Post: 02-26-2009, 06:43 PM
