586,076 active members*
3,932 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > iGolden CNC - buying machine from China, are these components good? Please advise!
Results 1 to 17 of 17
    Nov 2019
    5
    Greetings CNC Fellowship!
    My name is Geochi,
    I am setting up a workshop here in Spain (I moved from the States 2 years ago), and am looking to purchase a CNC machine from China. Have found the iGolden CNC on AlieExpress and have been in communication with their rep on WhatsApp. He has been quite helpful.
    The machine I was looking to get was a variation on this one - https://www.igoldencnc.com/woodworki...tary-axis.html
    The agent (he calls himself Benson) - provided me with the major components list and the manufacturer names. Would anyone please give me some feedback what it is I am dealing with quality wise and what can I expect:
    main components list:
    1.spindle:9kw HQD brand air cooling tool changer spindle
    2.Motor :Import Yaskawa(brand) servo motor and driver
    3.Guide rail:Taiwan HIWIN(brand) square guide rail
    4.Ball screw:German TBI(Brand) ball screw
    5.Gear:Taiwan XINYUE(Brand) rack pinion
    6.Control system:Taiwan LNC(brand) control system
    7.Inverter:China Fuling(brand) brand inverter
    8.Vacuum pump:China Tengyi(brand) vacuum pump
    9.Electric part::world famous CHINT(brand) electric parts
    Has anyone dealt with iGolden CNC and their machines by any chance?
    Re: iGolden CNC - buying machine from China, are these components good? Please advise
    if budget is enough, Italy HSD9kw air cooling spindle and Germany Becker pump is also a nice choice.
    You can choose the ABBA(brand) square guide rail for your machine. and Germany Becker vacuum pump if budget enough.
    Nov 2019
    5
    Thank you for the suggesions - could you please explain as to why you think these are better (especially the square guide rail, as it was not even mentioned in the list I noticed)?
    just a suggestion to get a good machine.
    you can e-mail me, I will explain for you.
    [email protected]
    Nov 2019
    4
    Good afternoon. The first obvious advantage of using CNC machines is a higher level of production automation. Cases of intervention by the machine operator in the manufacturing process of the part are minimized. I took parts from china. I even took a loan for them. Everything works. Good luck.
    You can choose to replace the latest machine
    Supply Forever Global Industry Co., Ltd.:https://www.supplyforever.com/
    Nov 2019
    4
    I can mail you?
    May 2020
    Horrible company
    They don't deliver on time and don't honor their word
    Jun 2020
    Hello Geochi,
    I am also looking at a machine from iGolden CNC. Did you end up buying one and if so how was your experience?
    Kind Regards,
    Matt
    Jun 2021
    hi there i have bought a GodelCNC machine yesterday, did you recieve it? how you can work between LNC and vectric?
    Sep 2021
    I recently purchased one of their machines for aluminum processing. HORRIBLE MACHINE !!
    1. I paid the deposit in April, the machine arrived mid-September, 5 months late than promised
    2. it came fallen apart. Loose parts dangling inside the panel.
    3. No Power plug.
    4. NO manuals or even hand-drawn instructions of any sort
    5. Software they send is so outdated it needs Windows 98 to run.
    6. Even though I specifically told them the machine needs to work with Australian electrical systems, water pumps had euro or Chinese plugs on them.
    7. Worst of all the machine is the wrong voltage for Australia. I asked them about it and they told me to buy a transformer for $1300 USD. When I told them the machine needs to work in Australia and it is their responsibility, they tried to pin that on me and called me ungrateful. So far I have spent $15,000 AUD and still don't have a working machine. I found this company on Ali Express but they did not process the sale through aliexpress. Now I know why! DO NOT BUY FROM THIS COMPANY! They will send you something even the TIP will charge you an arm and a leg to dispose of as the monstrosity they send is 1600Kg's. BTW, they also charge you delivery yet Chinese port charges will equal the price of the machine which no one talks about.
    Apr 2004
    475
    HQD spindle is a knock off of HSD spindle which is Italian. FYI, price difference should be about 8k so don't get ripped off paying the good price for the knock off.
    However, my HSD spindle died and I tried the HQD instead of a more expensive rebuild and it's been ok. I have other posts describing my issues but they might be unique to me.
    But, in general, I would browse the forums here and see which Chinese companies are doing well right now.
    Our company bought an omni Chinese machine (new) and have been happy with it. I have an older Jinan quick CNC and it's also been ok.
    Greg
    Sent from my Nokia 3.4 using Tapatalk
    Sep 2021
    I bought stone cnc router from igoldencnc company, the machine has been put into production normally. very satisfied with the quality!
    Sep 2021
    4
    This is a good machine
    Aug 2022
    how did you get on did you use igoldencnc I am considering using the for a laser cleaning machine would you recommend them?
    Aug 2022
    Which machine do you think is good the one from igoldencnc I am considering buying a machine from them but cannot find any details on there after service or reviews and obviously concerned on the quality.
  1. Advise about cnc 1224 machine from china (OMNI)
    By vaskenet in forum Chinese Machines
    Last Post: 02-01-2016, 10:04 PM
  2. advise buying cnc mill machine
    By dylan0806 in forum PCB milling
    Last Post: 10-19-2015, 06:12 PM
  3. things to consider when buying a machine from china...
    By B-Nasty in forum Chinese Machines
    Last Post: 02-01-2014, 11:01 PM
  4. buying a machine from china
    By jbobrout34 in forum Chinese Machines
    Last Post: 12-25-2013, 09:13 PM
  5. Buying a machine from China?
    By blue^ray in forum Commercial CNC Wood Routers
    Last Post: 05-10-2009, 04:26 AM
