586,077 active members*
3,870 visitors online*
    Nov 2019
    Laser machine is disconnected
    Could you give me an advice please?
    I bought a laser with motherboard m2 nano (80w 1060 chinese). I installed coreldraw and corellaser, listed id motherboard, connect usb cable and usb dongle,but it still reports to me Laser machine is disconnected.
    Please advise what I'm doing wrong?
    Photos from installation attached.
    Thank you very much.
    Sep 2005
    106
    Re: Laser machine is disconnected
    i bought the same machine, I also could not get it to work. I ended up removing the control board and replacing it with a cohesion 3D board and lightburn software. It works very nicely now
    Nov 2019
    Quote Originally Posted by bcer960 View Post
    Thanks. And just replace the board and reconnect the connectors and install lightburn or something else needs to be changed into the laser?
    Sep 2005
    106
    Replacing the board, and light burn will make it fully functional, but i also added a water flow meter, an amp meter and moved the cross hair button and table lift and lower buttons toa new panel.
    But those things are just "nice to haves"
  1. Disconnected bar feeder and now Puma will not run
    By runninwideopen in forum Daewoo/Doosan
    Last Post: 02-16-2022, 01:22 AM
  2. Kmotion - Disconnected !
    By Salexxx in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-05-2017, 07:56 PM
  3. Connected-disconnected loop
    By geppo in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-16-2014, 04:38 PM
  4. tacho generator disconnected
    By scr in forum DNC Problems and Solutions
    Last Post: 07-16-2007, 04:28 PM
