586,112 active members*
2,999 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
Page 4 of 7 23456
Results 61 to 80 of 128
  1. #61
    Nov 2007
    361
    Re: 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
    Quote Originally Posted by john-100 View Post
    I've had odd results with windows either not seeing new hardware or loading drivers correctly first time the PC boots
    Do you have a multimeter to check the 5V supply to the rotory encoder ?
    once you confirm the 5V supply is correct
    measure the voltage between the common 0V and A output
    depending on its position when stopped you will either have 0V or +5V
    while your rotating the knob the output will switch between 0 & 5V (50% of the time at 0V and 50% at 5V)
    ( see the Quadrature outputs here :-
    https://en.wikipedia.org/wiki/Incremental_encoder )
    your meter will read the average 2.5V
    you should see the same measuring between 0V and the B output
    John
    Hey john do you by chance know what the bios settings should be for the 2nd printer port pci card ? there are choices ecp/epp and another one I dont know off hand? what should the 2nd priner port card be set to in this setting? I ask because I think there is a problem with either windows and the drivers or the card it self and the reason is I set all my settings and the selector switch works but when I turn off the computer and turn it back on it does not work I have to go back and forth resetting the settings and I think it is the computer resetting itself do you have nay ideas?
  2. #62
    Mar 2007
    2083
    set to EPP
    what do you see in device manager ?
    any thing like this windows 10 PC I use to connect to the internet
Name:	printerport device manager.jpg
    John
  3. #63
    Nov 2007
    361
    set to EPP
    John
    John I checked with a multimeter on the inside of the mpg on the red and black wire 5v and 0v I only have 3 on my meter??
  4. #64
    Mar 2007
    2083
    where did you take the 5V supply from ?
  5. #65
    Nov 2007
    361
    The usb from the back of the pc
  6. #66
    Mar 2007
    2083
    One possibility is they have used the wires in an unusual way and not made
    the black wire 0V and red wire +5V
    In a ready made cable all that matters is the wires connect the correct terminals at each end and not the colour of the wires
    Attachment 433144
    the red & black wire should go to the outer two terminals
    Another possibility is the USB port is limiting the available current wit no connection to the data terminals - if I remember correctly phone charger cables have a 100 ohm resistor connecting the data terminals
    I would expect the encoder to take enough current to be a problem
    but I'll have a look for some data sheets to see what the typical current they take
    john
  7. #67
    Nov 2007
    361
    Attachment 433144
    john
    I have tried 2 different usb cables 1 was from a usb plug that went from the usb plug to a phone usb plug ,I cut the phone end off and spliced into that ...plugging the other end into the back of the pc...the 2nd cable was a wall phone charger that plugs into a typical wall plug ,I cut the phone charging port off the end and spliced into that and plugged the other end into the wall (120 plug) . Both ways in the end only have me 3 volts . I battled with the printer port card parameters last night and I'm not having much luck there either , I set mach3 to the right settings and no response from the mpg then I change the hex address to the printer port 2 ( because it has 3 different addresses) to a different address until 1 of the 3 listed works . I got to that point last night before I gave up for the night , so i think I'm gonna buy a different pci card other than star tech it is a standard pci parallel port card but maybe a different brand ...do you think changing the slot the card is plugged into would change anything for the better
  8. #68
    Mar 2007
    2083
    After reading various posts about problems with printer port cards
    from what I can tell the results depend on the chip set used
    a few chipsets referred to in adverts
    MCS9901CV Chipset
    MCS9865 Moschip Chipset
    Netmos 9865 Chipset
    WCH382
    unfortunately I don't have a definitive answer as to which adaptor works
    I have just plugged a USB cable into the PC I'm using and measure 5.1V with no load
    as its 1:23 AM I'll log off and try in the morning with a 1/2A and 1 amp load
    John
  9. #69
    Nov 2007
    361
    MCS9901CV Chipset
    Netmos 9865 Chipset
    WCH382
    John
    Thanks john do u think my meter might not be able to read that
  10. #70
    Mar 2007
    2083
    At best on the the 300DC range the reading will be plus or minus 1V , possibly plus or minus 2V
    so its not going to be easy to read the 5V supply with any certainty
    On the other hand your meter is ideal for working on the mains electrical supply
    no current range you can short circuit the mains supply with the test probes
    you just need to remember not to have it on a resistance range on a live circuit
    For your low voltage test like the USB supply a multimeter like this would be better
    Attachment 433226
    on the 20V range you measure to 2 decimal places
    off load I would expect you to measure 5.1V
    and a minimum of 4.75 V with a half amp load on a USB port
    John
  11. #71
    Nov 2007
    361
    Attachment 433226
    John
    I see ok so I will get a meter like that one in the picture ...so could this be the reason y I dont see 5 volts and only see 3 ??
  12. #72
    Mar 2007
    2083
    A meter with only a 300V DC range can certainly explain reading 4V
    as 4.99V will read 4V on the 300V range
    add a plus or minus one digit tolerance and the 5V can easily be displayed as 3V on the 300V range
    on a meter with a 20.0 or 30.0V range you will see the 4.99V as 4.9V
    probably alternating between 5.0 and 4.9 as its so close to 5V
    John
  13. #73
    Nov 2007
    361
    John
    Hey john I just got the volt meter in and I do have 5.01 volts on the red and black wire , so I checked the 0v and A signal and got the same reading and as I turned the rotary dial on the encoder the volts stay the same . see photos
  14. #74
    Mar 2007
    2083
    OK
    powering a new rotary encoder from 4.94V
    when the outputs are not connected to any load
    stationary I have
    0.11V between 0V and A
    0.12V between 0V and B
    3.7V between 0V and A-
    3.7V between 0V and B-
    while rotating
    approx 2.2V between 0V and A
    approx 2.2V between 0V and B
    approx 1.6V between 0V and A-
    approx 1.6V between 0V and B-
    John
    PS
    the current taken from the 5V supply by the rotary encoder is 0.1A with no load on the outputs
  15. #75
    Nov 2007
    361
    OK
    stationary I have
    while rotating
    John
    So since I have 4.98 volts rotating or not it would be safe to say the encoder is bad?? And the selector switches dont work either
  16. #76
    Mar 2007
    2083
    It does look like your encoder is not working
    what current does your encoder take from the 5V supply ?
    John
    PS
    looking for a datasheet for a rotary encoder
    I found this -
    https://rhonmac-cnc.co.uk/rotary_encoder_data_sheet.htm
    PPS
    what do you measure between 0V and A- or 0V and B- ?
  17. #77
    Nov 2007
    361
    John
    PS
    I found this -
    PPS
    Between 0v and A- I get .01 and the same with 0v and B-
    When I rotate the encoder it does not change the 5 volts
  18. #78
    Nov 2007
    361
    John
    PS
    I found this -
    PPS
    What do you think about trying to run the 5v and the A and B signal wire to that ol tonsen bob or would that work?
  19. #79
    Mar 2007
    2083
    the 5V from two USB ports can power the rotary encoder and second BOB in post 23
    you can only connect the A & B outputs to 2 of the 5 inputs ( pins 10 to 13 + 15)
    Attachment 433324
    To connect the rotary encoder to the tonsen bob
    Attachment 433326
    power the encoder from 5V from the USB port and the tonsen BOB from 24V -
    its onboard regulators will drop the 24V supply down to 5V - don't see an easy way to take 5V from the BOB
    ( a C10 BOB has the option to set pins 2 to 9 as inputs as an alternative
    to the C22 pendant interface )
    John
  20. #80
    Nov 2007
    361
    Attachment 433324
    Attachment 433326
    John
    I have a c22 board...but I guess that wont help
Page 4 of 7 23456
  1. 8 spindle rotary Cnc router making craket bat
    By omnisales6 in forum Videos
    Last Post: 06-29-2016, 04:02 AM
  2. Replies: 3
    Last Post: 12-20-2012, 07:09 PM
  3. Replies: 9
    Last Post: 07-05-2012, 08:57 AM
  4. Router Won't Turn On At Beginning of Program
    By notselrach in forum DNC Problems and Solutions
    Last Post: 02-06-2009, 10:08 PM
  5. G-Code to turn on and off router, non-spindle
    By Sam A in forum G-Code Programing
    Last Post: 10-25-2008, 02:02 AM
