586,114 active members*
3,256 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
Page 6 of 7 4567
Results 101 to 120 of 128
  1. #101
    Nov 2007
    361
    Quote Originally Posted by john-100 View Post
    Yes
    That BOB will be easier with the screw terminals to connect to
    Attachment 431332
    I would still use the larger 1XHCEL Board relay to keep the mains away from the BOB !!!!
    Attachment 431334
    PS
    2nd BOB to 1XHCEL relay board
    Attachment 431338
    Attachment 431336
    John
    Hello john ,
    I'm just now getting to wiring this up I have a question ....in the diagram it shows a green box labeled spindle control is this going to be the ( modified power supply with the potential dial ) or is this the actual spindle motor
  2. #102
    Nov 2007
    361
    Re: 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
    I really needed specific locations I know the wires go to the spindle control box but where? and the diagram shows a battery ?? could this be the 12 volt power supply I have added ? HELP PLEASE
  3. #103
    Mar 2007
    2083
    post 101 - the green box is a mains powered load switched on & off by the relay
    in the diagram its shown as a pump but in your case it can be the speed control for the spindle motor
    post 102
    if its the 12V supply shown on this diagram
    Attachment 435552
    then yes
    photos of the boards you are now using in your machine will be useful and the manufactures part numbers
    so I can double check what you have now
    John
  4. #104
    Nov 2007
    361
    post 102
    Attachment 435552
    then yes
    John
    Hello john ,
    Here is a list of what I have in my controller box
    1st picture is 12 volt power supply to run my fans inside the box .
    2nd picture is of the spindle control box that has the pot knob and it is 48 volt output
    3rd picture is a view of the terminals of the spindle control box
    4th picture is of the other power supply running the stepper drivers
    5th picture is of the terminals of that power supply for the stepper driver
    6th picture is the 5th axis breakout board
    And the 7th picture is the relay for the spindle
    The last picture is of the new enclosure which is an old pc that I have converted into a new enclosure there is still a few loose ends there so please feel free to give suggestions
  5. #105
    Mar 2007
    2083
    Hi Michael
    Its going to take a little time to produce a wiring diagram for the connections of the contactor to the spindle motor speed control / power supply
    provided the relay can cope with the switch on surge current
    use the relay to switch the mains supply to the spindle speed control / power supply
    needs work but this is a start until I have sorted out the PC
    Attachment 435654
    I need to make space on this PC's 2Tb C drive as it only has 2.54 Gb of space !
    having downloaded some very large files today
    I need be able to use it to buy tickets at 9 am tomorrow for a concert in October so I don't want to dig my self into a hole just now
    its too easy for a simple job to turn into a nightmare - been there done that
    Once I have the tickets
    I can leave it backing up / moving files all day, including while I at the Caravan Palace concert
    {they are a French electronic music band }
    John
  6. #106
    Nov 2007
    361
    Hi Michael
    Attachment 435654
    John
    This is perfect for a start ...no problem john when ever u get time and have the resources. You have been a very big help they all of this . Thanks in advance for all the help
  7. #107
    Mar 2007
    2083
    Hi Michael
    it is still a work in progress but is a wiring diagram for the spindle
    if your not using a charge pump
    Attachment 435834
    note- the BOB shown needs a 5V supply from a USB port
    John
  8. #108
    Nov 2007
    361
    Hi Michael
    Attachment 435834
    John
    Looks good john I have 1 question what's the no volt release switch for ? What would that switch be used for??would I use it everytime I run the machine or just when I need to shut the spindle off like a estop
  9. #109
    Mar 2007
    2083
    while you can do without a no volt release switch
    The no volt release switch prevents the spindle from starting unexpectedly
    after a temporary loss of mains supply or when you switch on the power to your workshop
    When using A PC's printer port the outputs will be at random levels at start up
    until windows & mach3 are running correctly and has control of the printerport
    John
  10. #110
    Nov 2007
    361
    John
    Oh I see do u have a recommendation, brand , type ??
  11. #111
    Mar 2007
    2083
    a no-volt release switch used on many mini lathes and milling machines is the
    KJD17 5-Pin Start / Stop No Volt Release Switch
    Attachment 436052
    there is a 4 pin version but the 5 pin KJD17 makes it easier to add remote stop switches
    seeing your location you need the 120V version that the likes of Little Machine Shop sell
    https://littlemachineshop.com/produc...5527&category=
    not the 240V version I would use in the UK !
    if you don't have to keep the cost to a minimum
    a Direct On-Line (DOL) Starter is an alternative
    with some manufactures you can buy DOL starters with & without a current over load
    and various coils AC or DC for 24C , 50V , 110V , 240V & 420V use
    https://uk.rs-online.com/web/c/autom...led%22:true%7D
    Attachment 436060
    https://www.electronicshub.org/dol-starter/
  12. #112
    Nov 2007
    361
    Attachment 436052
    Attachment 436060
    Hey john I have finally got this all hooked up besides the e stop ..so I only need to use the live wire in the e stop and back out of the estop??
  13. #113
    Nov 2007
    361
    Referring to post 107
  14. #114
    Mar 2007
    2083
    assuming you have the KJD17
    a N/C E-stop switch can be wired between the KJD17 terminals A1 and 24 to remotely switch off the KJD17 and kill the mains supply to the machine
    if you find a 2 pole N/C plus N/C E -stop switch instead of the more usual N/C plus N/O you find on the likes of E-bay
    the second N/C contact can signal an E-stop to the PC
    this has the advantage that a brocken wire to the PC N/C E-stop will be detected
    using a N/O contact works but does not detect a broken wire !!
    (some E-stop switches are available as the push button mechanism that you have to buy the individual N/C or N/O switches but they are usually more expensive )
    see page 12
    https://docs.rs-online.com/3897/0900766b816e95d8.pdf
    John
  15. #115
    Nov 2007
    361
    This is the estop I have
  16. #116
    Nov 2007
    361
    That does sound like a better e stop but for now I will hook this one up thru a1 and 24 terminal until I get the new n/c , n/c estop
  17. #117
    Mar 2007
    2083
    yet another version of an E-stop switch with just 3 terminals - a common . N/C and N/O
    with this switch you can either connect it to the KJD17 terminals to kill the mains supply
    or to the BOB to signal an E-stop to the PC but not both
    killing the mains supply will stop the machine once the energy stored in the power supplies is used up
    an E-stop to the PC via the BOB only works if the PC and control electronics is working correctly
    I have had motor drives fail and run away with motors running over speed in an uncontrolled way !!!
    (series pass transistors go short circuit and apply full power to the motor )
    John
    PS
    if you use your E-stop switch to control the KJD17
    a small 120V AC relay could be connected to the KJD17 output
    the relays N/O contact can then be connected to the BOB's E-stop input
    depending on your parts suppliers this could be less expensive than a E-stop switch with N/C plus N/C contacts
  18. #118
    Nov 2007
    361
    John
    PS
    I agree with u on this john and this is the whole point of adding the relay was to be able to have more control over the machine when the estop is needed . So I am ordering the n/c n/c estop to be able to connect the bob and the relay to the same estop , I will let u know when it arrives
  19. #119
    Nov 2007
    361
    see page 12
    John
    John I need ur help ...I got the estop u recommended n/c n/c .....can you please draw out a diagram I see in the post from the 1st time you drew it out but I cant make heads or tails of it . I use the 24 from the no volt on /off switch to the 23 on the e stop then out of the estop to the relay. I am not sure what to do with the a1 terminal??
  20. #120
    Nov 2007
    361
    Quote Originally Posted by Michael82 View Post
    John I am having trouble with understanding the a1 terminal...I got the 24 terminal going to the relay
Page 6 of 7 4567
  1. 8 spindle rotary Cnc router making craket bat
    By omnisales6 in forum Videos
    Last Post: 06-29-2016, 04:02 AM
  2. Replies: 3
    Last Post: 12-20-2012, 07:09 PM
  3. Replies: 9
    Last Post: 07-05-2012, 08:57 AM
  4. Router Won't Turn On At Beginning of Program
    By notselrach in forum DNC Problems and Solutions
    Last Post: 02-06-2009, 10:08 PM
  5. G-Code to turn on and off router, non-spindle
    By Sam A in forum G-Code Programing
    Last Post: 10-25-2008, 02:02 AM
