586,082 active members*
3,772 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > Plasmacam Issue With .DXF Import
    Nov 2019
    I'm a tech ed. teacher and one of my assignments has my students create an extruded object in Autodesk Inventor, export the face as a .dxf file, and import this .dxf file in Plasmacam. Most of the time it works just fine. However periodically we get these stray lines that connect to the origin of the cut area as shown in the image. I have not found an obvious reason for these lines nor have I been able to get rid of them consistently. Anyone else seen this or have suggestions?
    Nov 2010
    177
    Re: Plasmacam Issue With .DXF Import
    What image?
