586,036 active members*
3,706 visitors online*
Results 1 to 9 of 9
    Anyone use Centroid control on a VMC?
    I'm curious what it would take to get a controller like the Oak to work with a ATC. Lots of custom PLC programming, or is a carousel tool changer pretty routine thing that would be sort of plug and play? I also have a shot pin spindle orient on this machine and that seems like it might be somewhat non-standard.
    It's a '93 VF-1 that I'm needing to retrofit. Seems like it would have been done by many others at this point but I don't see a lot online (DIY type retrofits anyway).
    Jan 2010
    44
    Re: Anyone use Centroid control on a VMC?
    If you go here
    https://centroidcncforum.com/viewfor...670e3ee4b6112a
    to centroid's website and search on "vmc" you will find several instances of people converting their machines to Centroid CNC, though none seem to specifically state VF-1.
    HTH
    Thanks. I found one post by a guy asking similar questions. It wasn't really answered. I guess I'll find out soon enough. I'm pretty sure the spindle orient can be handled by the system, just not sure how much work I'll have to do. I've looked into adding a spindle encoder and it doesn't look too bad for these machines. I've even heard of kit but haven't seen any such thing in the wild yet.
    Dec 2009
    521
    Quote Originally Posted by Sam_Beckham View Post
    Sam, they have a "Standard" umbrella PLC. You would have to check to see if your Umbrella changer is typical, slide in out, drawbar clamp unclamp, Tool 1 sensor, Tool counter, forward/reverse carousel motor etc. Best to post on the Centroid CNC User's forum and ask the question. You'get quicker responses there: https://centroidcncforum.com/viewforum.php?f=64
    Post pictures of your machine, make and model, pictures of the control cabinet, close ups of the servo drives, pictures and lables of the servo motors, pictures of the spindle drive and spindle motor etc.
    I will do that. I haven't bought a control yet so I was hesitant to post the question on their forum. I think I've pretty well decided I'm going to go with the Oak though.
    Added some pics. Not much to look at yet. DMM is still building the servos and the VFD is backordered. I do have quite a stack of boxes from Automation Direct, Grainger and MSC piled up out there now though. Lots of wiring to deal with in the mean time. I plan on starting to get a few things mounted in the cabinet and finishing up the servo adapters this weekend.
    Nov 2013
    152
    Good looking machine!
    I have Centroid on my 5’ x 8’ cnc router. Just started a cnc mill retrofit that will also get Centroid. Very happy with their control.
    Dec 2009
    521
    Contact Alfa Controls. They have developed a Centroid Retrofit solution for older HAAS Machines: https://youtu.be/IfyJuZG4pkU
    Industrial Automation Solutions Integrator | Alfa Controls
    Thanks Marty. I saw that and that's actually what turned me on to Centroid controls. Not sure how willing they would be to sell me their PLC programming but if I get stuck it's worth a try.
    Dec 2009
    521
    I think you would be far better off to buy from them. You would need to know all their IO connections. You could email and ask them for a price for their schematic and report file. They may be willing to sell it to you.
  1. EMC to control Centroid CNC 4
    By tpwjayson in forum LinuxCNC (formerly EMC2)
    Last Post: 06-21-2011, 08:03 AM
  2. Centroid Control How do i......
    By ABI in forum Uncategorised MetalWorking Machines
    Last Post: 11-01-2009, 01:55 PM
  3. Is a Centroid M15 and M15 cnc control the same thing?
    By squale in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-25-2008, 04:49 AM
  4. Question about Centroid M-400 control
    By ValleyFab in forum Centroid CNC Control Products
    Last Post: 08-19-2005, 01:37 AM
