586,106 active members*
2,987 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Bent carousel plate???
Results 1 to 3 of 3
    Feb 2011
    Has anyone ever had issues with certain areas of the umbrella not fitting tools? My machine gets stuck when it trys to place a tool around pocket 16-19 I believe... I need the extra pockets, any ideas?
    Apr 2014
    345
    Re: Bent carousel plate???
    Bent shaft that holds the platter?
    Run an indicator on the plate and see how far it’s out. Also take a straight edge on the bottom and check the flatness. If it has a lot of run out but checks out flat you probably need to disassemble and check the shaft straightness.
    Mar 2008
    683
    Have you tried resetting the pocket position and reloading the tools. This will let you see if it is the pockets themselves or will at least help troubleshoot what is causing the misalignment.
  1. ATC bent spindle
    By Thad92 in forum Auto Tool Changer
    Last Post: 07-12-2017, 09:18 PM
  2. Bent screws or something else?
    By jonnyk2 in forum Linear and Rotary Motion
    Last Post: 01-24-2017, 05:56 PM
  3. Bent Too Much?
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 02-20-2009, 05:25 PM
  4. .125" AL plate, cut (mill or laser), bent .125" ID bends
    By Sporqster in forum Employment Opportunity
    Last Post: 09-23-2008, 09:41 PM
