587,006 active members*
3,156 visitors online*
Thread: Visual mill
Results 1 to 7 of 7
    Jun 2007
    5
    Smile Visual mill
    I could use a little help or advice. I am currently using Rhino to draw my part and Visual mill for my cam prgm. When I load it into Mach3 and run the prgm in the toolpath the screen show a very jerkey and slow cutter path. Also the dro shows the same jerkey motion (one axis moves then stop and the other catches up) . I am running the demo version and have not hooked anything up to my machine yet. and yes I am verrrrry impressed with mach3 so far. I believe that it is probly something in the postprosser from Mecsoft but I am not sure. Any help or advice would be greatly appreciated:
    Aug 2005
    828
    I use the same process as you and I get G-code that works every time. Are you using the Mach2 post in Visual Mill? Did you run a driver test to see if your computer runs Mach nicely? Do you have a on board video card?
    Dennis
    Jun 2007
    30
    Is rhino free? If so, where can I download it. I saw a download at the mecsoft site but that was a plugin not the actual program itself.
    Aug 2005
    828
    Rhino is not free.
    Dennis
    Jun 2007
    5
    I found the problem. seems that I am not to smart at times. When you set up the postproceser in visual mill you have a choice in running abs, or inc,. When you set up mach3 ya better set it up the same way or you can have problems. It might run like mine did but you can get some real strange cutter movement. (whatadummy) . As far as Rhino goes you can go to there website and get a demo. And if you like it and have someone going to collage or teaching you can get it for $195. Personaly I think it is a great cad prgm,
    Apr 2006
    47
    Quote Originally Posted by DennisCNC View Post
    Is that how it is supposed to be set up? w/Mach2 post? (I am running Mach3 here also)
    Aug 2005
    828
    ^^ Not sure if it is the right way, but I get good code every time for Mach3.
    Dennis
  1. Looking for Visual Mill users
    By ninewgt in forum Visual Mill
    Last Post: 02-04-2011, 10:29 PM
  2. Bob CAD or Visual Mill
    By nandomax in forum Uncategorised CAM Discussion
    Last Post: 05-25-2007, 02:55 PM
  3. Need help with VISUAL MILL
    By replicapro in forum Visual Mill
    Last Post: 06-18-2006, 04:06 PM
  4. ONE CNC or Visual Mill ???
    By ninewgt in forum OneCNC
    Last Post: 07-07-2005, 03:56 AM
  5. Visual Mill 5.0
    Last Post: 02-06-2004, 05:00 PM
