586,052 active members*
4,038 visitors online*
Results 1 to 6 of 6
    5v proximity sensors
    Hi i just got some of these: https://www.ebay.com/itm/DC-5V-M12-N...oAAOSwJ-pZulBz
    And they say 5v working power.
    Do i still need the optocoupler for this? Or can i just wire it straight to the limit and gnd?
    Mar 2007
    2083
    Re: 5v proximity sensors
    What breakout board or motion control do you want to connect the 5v proximity sensors to ?
    why do you think you need a optocoupler ?
    John
    24221
    They don't mention whether open collector or includes a pull up resistor, either way you would need one, I assume that they are 5v for use with TTL logic or a micro-processor for e.g.
    Al.
    Albert E.
    I have a cncrouterparts CNC, but with the mk3 USB controller from planetCNC.
    Reasons why i thought so was that i could not find any documentation of anyone using the 5 volt sensors. And all i have seen have been 12v or up.
    I am fairly new to all this. So..
    Mar 2017
    1312
    Both open collector and TTL sensors should work well with PlanetCNC controllers.
    Mar 2007
    2083
    Going by a photo of the mk3 USB controller
    I expect its based on a CPU like the Atmel AVR or ARM Cortex used in versions of the Arduino
    with no circuit to buffer protecting the TTL compatable inputs of the mk3 USB controller
    Using the LJ12A3-4-Z/BX-5V has the advantage it can be powered by the +5V from the mk3 USB controller -
    you will need to check the total load on the 5V output for the stepper driver inputs & proximity sensors
    provided the NPN sensor outputs have true open collectoroutputs - with no pullup either inside the sensor or an external pull up resistor
    you should be able to use sensors powered by a 6 to 36V as usually found on line
    So far I have not found a data sheet
    this is what I have found for the 5v proximity sensors - N/C NPN output
    Attachment 431326
    so the proximity sensors will act like the micro switches shown on page 18 of the mk3 USB controller manual
    Attachment 431328
    while its easier to have sensors with N/O NPN outputs in parallel
    I prefer to use sensors with N/C PNP outputs connected in series
    for control boards like the mk3 USB controller you can use a NPN transistor or an opto isolator
    to convert the positive supply out from the PNP sensor outputs into a NPN switch to ground
    with N/O switches the control will not detect a broken switch wire
    with N/C switches the control will see a broken wire as a tripped limit switch
    John
  1. Npn NO proximity sensors
    By Kal22378 in forum CNC Machine Related Electronics
    Last Post: 05-18-2018, 05:16 PM
  2. how many proximity sensors?
    By RobSm in forum CNC Machine Related Electronics
    Last Post: 01-18-2017, 09:02 AM
  3. Turck proximity sensors
    By hacker7 in forum DIY CNC Router Table Machines
    Last Post: 11-02-2013, 05:27 PM
  4. proximity sensors
    By FordGalaxy in forum Benchtop Machines
    Last Post: 06-02-2012, 09:36 AM
  5. proximity sensors
    By wired in forum CNC Machine Related Electronics
    Last Post: 09-30-2005, 05:29 PM
