586,103 active members*
3,859 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Lower bearing noise solved for now
    Mar 2007
    21
    Hi all:
    I had this annoying squeak come about from the spindle cartridge, I was in the middle of a project and did not feel like tearing into the cartridge to re-grease the bearing. I know my bearings were being washed out by the spray of coolant, so I simple followed suit with a thinned out grease that I blew in with compressed air from the bottom. Quiet now and very smooth running.
    This is something I thought I would share, I by no means imply that this is a solution for replacing proper maintenance, but maybe someone might find themselves in the same predicament and will find this idea useful.
    Jun 2014
    1780
    Re: Lower bearing noise solved for now
    For a quick fix thats a good idea, I never thought of that!
    Coolant will get into the lower bearings, I made a slinger for mine to keep that from happening, original spindle, machine will be 8 years old in February.
    I tried water based coolants for the first couple years, got tired of the sludge in the sump,pump sticking, rust etc
    mike sr
  1. GDZ-80-2.2B weird noise on lower RPM
    By yllar in forum Spindles / VFD
    Last Post: 02-05-2019, 08:52 PM
  2. Ordered an extra Lower AC bearing... anyone want it
    By DarkStarMedia in forum Charter Oak Automation Support Forum
    Last Post: 05-31-2012, 06:11 AM
  3. TL-2 SPINDLE BEARING NOISE
    By WOLOG in forum Haas Lathes
    Last Post: 06-06-2011, 08:28 PM
  4. X2 Bearing noise
    By C.BRAXMAIER in forum Benchtop Machines
    Last Post: 10-01-2008, 12:46 AM
  5. Help! Spindle Bearing Noise
    By petriej in forum Uncategorised MetalWorking Machines
    Last Post: 02-26-2008, 08:15 PM
