586,096 active members*
3,754 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Usual Power Supply???
    Oct 2006
    46
    What's everyone's favorite power supply for Gecko 320 & 340's??? Self-built, regulated, rackmount...?
    Also, is there any merit in providing a separate supply for each of the drives vs. just one supply capable of outputting the amperage for all 3 servos of a 3 axis system?
    Sep 2012
    8
    I have used gecko 320's before on my previous machine and have run 3 switchers and 2 large toroid supplies. It's less trouble to run convential supplies and you won't have to worry about spikes when a motor looses power and the magnetic field collapses trashing out your switchers. If you do decide to use switchers it would be wise to go to the Gecko site and look for a circuit they posted that can eliminate the issue. Their circuit used a TIP147 mosfet, a diode, capacitor, and a few resistors will give you protection from inductive kickback
    MGHood
  1. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  2. Usual silly questions
    By lgalla in forum Linear and Rotary Motion
    Last Post: 08-17-2007, 08:07 AM
  3. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  4. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
  5. Usual cost to turn down end of a ballscrew?
    By WoodSnarfer in forum MetalWork Discussion
    Last Post: 02-10-2005, 08:36 PM
