hi all,
i have a trouble with G31:
NOT WORK
G31X-20
G31Y-20
WORK FINE
G31X20
G31Y20
G31Z20
G31Z-20
hi all,
NOT WORK
G31X-20
G31Y-20
WORK FINE
G31X20
G31Y20
G31Z20
G31Z-20
It does not help that you have provided next to no information about your setup.
Since some G31 instructions do work for you, I don't think the problem is in the Mach SW.
Do you have limits set up?
Cheers
Roger
I am using a uc100 clone from usb to parallel using the mach3usb.dll on WIN10.
Using directly on LPT and windows XP work GCODE G31!
The machine is USB native and inside it has a PIC18F4550 chip the model of the card is a JP-382C.
Is there a firmware for JP-382C with PIC18F4550 to make it work with mach3?
In this way I could eliminate the clone UC100 USB / LPT converter.
I want use the USB interface with windows 10 if possible.
Thanks for your help.
This is the problem:
https://youtu.be/5rdCbcJC9oA
do you still have drivers for chinese uc100
clone ?
Sorry, can't help with the UC100 side of things. I use an ESS myself.
I do know that there is a problem with many LPT converters. Mach3 under XP uses the LPT port in ways a bit different from a printer, and many adapters cannot handle the extra features needed.
Cheers
Roger
Almost all Chinese controllers have problems with probing.
Ask the manufacturer.
