586,121 active members*
3,643 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas mini mill lubrication pump problem.
    Aug 2008
    28
    Would anyone have a photo of an older 2000 mini mill lubrication pump manifold/air/solenoid valve setup.
    I re piped the air system so that the air inlet gauges and regulators are more accessible and higher off the floor, but it has been a while and want to be sure that everything gets re attached properly.
    Thanks!
    Jul 2010
    172
    Re: Haas mini mill lubrication pump problem.
    Here are some pics of my set up.
    Basically original other than I've wired the lube pump directly into the 115vac so it runs all the time.
    If you need close ups or other angles, just let me know.
    Timothy
    Dyna Mechtronics DM4400, Bridgeport Discovery 300, HAAS VF-0E, HAAS VF-2D
    BobCad 16, 20, 24 and now V25
  1. Haas Mini Mill Homing X Limit Switch Problem
    By esphobby in forum Haas Mills
    Last Post: 12-06-2017, 10:36 PM
  2. Haas Super Mini Mill 2 ATC problem
    By VectorBit in forum Haas Mills
    Last Post: 04-05-2017, 05:39 PM
  3. Haas Mini Mill Coolant Pump Issue
    By LockTech in forum Haas Mills
    Last Post: 12-15-2016, 08:42 PM
  4. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
  5. tool changer problem on haas mini mill
    By Greg 24 in forum Haas Mills
    Last Post: 03-05-2006, 09:20 PM
