586,112 active members*
3,159 visitors online*
    Jan 2006
    58
    Mastercam and PathPilot-Tormach
    I use Mastercam 2018 at work on a daily basis.
    The Owner was nice enough to give me permission to use it for my 1100-3 if I want. I use Fusion 360 at home, but really like Mastercam.
    Anyone know what post will work for the 1100? MC has many to choose from, but nothing for Tormach.
    I really don’t want to pay to have one written by the dealer.
    The 1100-3 does have an ATC.
    Thanks for any help
    Nov 2012
    591
    Re: Mastercam and PathPilot-Tormach
    If it has something for LinuxCNC (or the older EMC) then that should work fine.
    If it has "generic G-code with arcs" that should probably work OK, too, but be sure to find all G codes it uses, and verify that they work in Virtual PathPilot.
    Jan 2006
    58
    Quote Originally Posted by jwatte View Post
    Thank you!!
    Jan 2007
    311
    Can't tell you about the tool changer but I've been using the mpmaster_tormach post that's around for X3. Chances are good it would update into he newer MC. Free so worth a try and as above, you could test on the virtual PP
    M
    Jan 2006
    58
    Quote Originally Posted by Mooser View Post
    M
    Thank you.. I’ll give it a try!
  1. Pathpilot and Tormach post for RhinoCam 1
    By brian257 in forum Rhinocam
    Last Post: 09-16-2017, 03:55 AM
  2. Replies: 3
    Last Post: 08-03-2017, 06:27 AM
  3. PathPilot for Non-Tormach Machines?
    By SCzEngrgGroup in forum Tormach Personal CNC Mill
    Last Post: 04-13-2017, 03:41 PM
  4. non-Tormach Touchscreen with PathPilot
    By beunks in forum Tormach PathPilot™
    Last Post: 01-02-2017, 09:14 PM
  5. Which breakout board for Non-Tormach Pathpilot?
    By Nigel Tufnel in forum CNC Machine Related Electronics
    Last Post: 04-25-2016, 09:25 PM
