586,082 active members*
3,937 visitors online*
Thread: Earth Ground
Results 1 to 6 of 6
    Jul 2004
    97
    Earth Ground
    I Have 4 Cnc's And Was Just Wondering If They Each Need A Separate Earth Ground ( Copper Bar Driven Through The Concrete Floor Into The Ground) We Have Been Having Many Lightning Storms Lately And I Was Just Concerned. Normally I Do Not Run Them When A Storm Is Happening. My Electrical Service Is Grounded With An Earth Ground, But Is That Enough?
    Jan 2007
    333
    Depends on several things. Is there a phase converter involved? Step up/down transformers for main power? State Electrical Codes apply, for example Ohio's is different than Kentucky's. Is there hard (metal) conduit mounted?
    Apr 2003
    637
    Quote Originally Posted by LYN BYRD View Post
    Yes, that is all that’s needed and from what I have read and heard having a second ground can be dangerous. Do a search on this site or practicalmachinist.com for more information, it gets argued a lot.
    Jun 2003
    3312
    The objective of a safety ground (tied to earth) is to give a true 0V reference. That in turn should provide a non current carrying path throughout your electrical subsystem for safety-fault conditions. If you have not installed isolation transformers or power subsytems, then one should be enough. If there are isolation transformers, or power subsystems, there needs to be a ground rod for each. Safety ground should never carry current except in a fault condition. The metal frame on each of your machines should be tied to the safety ground.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jul 2004
    97
    Ground
    Phase Converter=yes
    Transformers=no
    Machine Ground Tied To Service Ground=yes
    Does Anyone Run Their Machines In A Lightning Storm?
    24221
    Generally if lightning strikes the incoming service there can be extremely high voltages being transferred through the system, and to some extent any amount of grounding is not going to protect the machine, personnel, maybe.
    Most parts of a CNC machine do not take to excessive over-voltage.
    There are expensive devices to either eliminate or decrease the chances of damage, one is SOLA regulators, these consist of Transformers that run around saturation so surges are not processed through them, but they tend to be inefficient, power wise due to running very hot (saturation).
    One of the things that often suffer the most are things like SCR drives etc, that operate across the line.
    Due to nothing to buffer them, the spike causes havoc with the firing sequence and often, either takes the fuse out, if you are lucky or blows the expensive switching device.
    Al.
    Albert E.
  1. How on earth do I make this!!!
    By disinformation in forum G-Code Programing
    Last Post: 10-11-2006, 01:53 PM
  2. Google Earth ( You'll love it)
    By ynneb in forum Community Club House
    Last Post: 08-05-2005, 07:13 PM
  3. Good earth ground, what is your definition?
    By gar in forum CNC Machine Related Electronics
    Last Post: 06-16-2005, 03:22 AM
  4. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
