586,113 active members*
3,573 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > NOT 90 DEGRRE CORNERS IN CUTTING A SQUARE
Results 1 to 10 of 10
    Feb 2017
    11
    Hi i have a cnc router that is from china, yes i know is from china the quality is not anywhere but i dont buy it i recive it like a payment from a debt that somebody owe me, the machine is having a issue, when you send a square to cut, at the end of the cut in every single side of the square the machjine cut in the inside of the square leaving not a 90 degree corner, i attached some pics of the issue.
    the software im using for cad is aspire, the type the g code that i save the file for use the machine is Mach2/3 Arcs(mm).txt and the software that i use for reading the g code is mach3. i use on pc for the cad software and another pc for the mach3.
    hope you can help me to find out the problem of my machine and thanks in advanced.
    Jun 2015
    4154
    Re: NOT 90 DEGRRE CORNERS IN CUTTING A SQUARE
    hy, try a quick fix : reduce feed before & after the corner; otherwise, look for the in-position parameter / kindly
    Feb 2017
    11
    sorry for this, im not expert in the subjet, in-position parameter? were is that? in mach3 or aspire?
    Jun 2015
    4154
    i don't know if that parameter exists on your cnc ... but if it does, it will save the day
    Apr 2004
    5737
    This might be happening because you have "constant contouring" set in Mach3. Try "exact stop" and see if it helps.
    Andrew Werby
    Website
    Feb 2017
    11
    thanks for your comments i will apply this solution and i gety back to you.
    1228
    Have you tried the same operation with a very shallow cut?It might be a way to isolate the problem-if its a machine parameter matter the same path will be followed but it its a machine flex problem it might not show the same deviation from the intended path.
    Change your program so you go past the corner then approach it from the side.
    Feb 2017
    11
    Quote Originally Posted by drdos View Post
    sorry for this but how is that change my program?
    Feb 2017
    11
    Quote Originally Posted by awerby View Post
    this config is setting in the generasl config tab in mach3?
  1. Square corners
    By bjay in forum CamBam
    Last Post: 09-26-2011, 02:20 AM
  2. Milling Square Corners
    By cnckid in forum MetalWork Discussion
    Last Post: 03-30-2011, 12:06 AM
  3. Inside Square Corners
    By Magnum164 in forum Tormach Personal CNC Mill
    Last Post: 08-29-2010, 04:07 PM
  4. square corners getting rounded off
    By SatanKlawz in forum Uncategorised CAM Discussion
    Last Post: 06-30-2010, 02:33 AM
  5. Radius's appearing in square corners
    By simso in forum Mastercam
    Last Post: 01-03-2009, 05:10 AM
