586,069 active members*
3,410 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > chainsaw bar oil for way lube
Results 1 to 10 of 10
    Dec 2006
    25
    Hello
    Has anyone heard of using bar oil for way lube? If not what way lube would you use for a series 2 copy knee mill with turcite on the way surfaces?
    Thanks in advance
    Joe
    Jun 2006
    440
    Quote Originally Posted by Cycle Start View Post
    Hello
    Thanks in advance
    Joe
    Turcite (Ethylene-chlorotrifluoroethlyene [ECTFE]) is a self lubricated plastic grade TA is blue and TX is red. Are the ways meant to have external lubrication? We make parts for mechanical slides where oil contamination is a no no so I don't know what types of oil it is compatable with. What references I have say it is chemically resistant, but no more. You could call Boedecker Plastics, which is where we get it, and ask them what type of oils are compatable with the grade you have. Their numer is 1-800-444-3485.
    Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
    Mark Twain
    Dec 2006
    25
    This is green in color. The mill has an automatic lube system on all of the ways. I do not know if it is turcite, but it is some type of anti-friction material.
    Jun 2006
    440
    The only material we work with that is green is oil impregnated nylon. Sorry I couldn't help.
    Mark Twain
    Jan 2004
    3154
    A waylube system SHOULD USE WAYLUBE.
    Every oil supplier can get you a "Waylube 60" product.
    This is the most common waylube and is used in every machine tool I have ever seen.
    www.integratedmechanical.ca
    Mar 2004
    1543
    Hello
    Thanks in advance
    Joe
    Chainsaw bar oil is way lube, just different name for different application. It cost more than way lube, at least if you by 5 gallon pails. I just use way lube in my chainsaw.
    Karl
    Mar 2006
    2712
    I have a sneaking suspicion that "chain oil" is like a 5 cent cigar. The oil equivelant of "floor sweepins' "
    DZASTR
    Jul 2005
    12177
    Quote Originally Posted by RICHARD ZASTROW View Post
    I think you are being too cynical . I think it is simply mineral oil with an additive to make it kinda 'sticky' so it doesn't run off of fling off easily.
    On Turcite I would use plain mineral oil. Turcite is acetal based and I know acetal (Delrin is acetal) is not affected by plain oil but I don't know if it is affected by the additives in way oil or chain oil. With Turcite these additives are not needed anyway.
    Nov 2005
    440
    Usually, I would never get in this discussion..any lube is better than none, but the petro engineers have worked real hard to make an oil ( way lube) that will lube and "unstick"..chainsaw oil was disigned to stick to the chain to lube it..Way oil was designed for Machine Equipment to lubricate, but avoid "stickem"...If your ruinning an accurate CNC Machine, go with the manufactures reccomendations..( a way lube) a "Hobby" machine, just keep some kind of lube on the ways, always, and keep the ways clean.
    Adobe (old as dirt)
    Mar 2006
    2712
    A cheap cigar with "stickum' "?
    DZASTR
  1. Which way lube oil?
    By WilliamD in forum Uncategorised MetalWorking Machines
    Last Post: 02-27-2007, 03:46 AM
  2. Lube
    By monte55 in forum Linear and Rotary Motion
    Last Post: 09-17-2006, 10:42 PM
  3. Tap Lube
    By Gitanes in forum MetalWork Discussion
    Last Post: 11-26-2005, 02:45 PM
  4. My first lathe! What lube to use?
    By gdl357 in forum Mini Lathe
    Last Post: 08-19-2004, 05:06 AM
  5. I need lube!
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 06-01-2003, 02:25 PM
