586,103 active members*
3,260 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Using Aspire and Cut 3d on the same project
    Nov 2019
    Ir I were to rough path and finish in different steps, alternating betweeen Cut3D and Aspire, would it explain why my projects had a displacement? considering both would have the same origin and dimensions marked.
    Re: Using Aspire and Cut 3d on the same project
    If you are 100% positive that the models are in the same place, then it should work fine. Not sure how you'd know for certain that they were, though.
