586,058 active members*
3,712 visitors online*
    Sep 2019
    5
    okuma slope machining
    i have a 2.5 insert endmill that i want to use in a BA=75
    how do i touch off tool?
    May 2015
    15
    Re: okuma slope machining
    Quote Originally Posted by okumamultus View Post
    How old is the Multus?
    The one im running is an Multus B250II with OSP-P300SA-H control on it.
    I just touch of in basic position (TD=XXXXXX) and use G52
    BR Masterblaster
    Jun 2015
    4154
    hy 8laster i guess is nice if you have experience with multus & LT's; so far, i have never worked on such machines ...
    it seems that he uses G52, like it is shown in his other thread, but i don't know what is missing; all the best
    hy, my 1st idea would be to let loose the B axis, and tilt the machine using a forklift ... should work
    i also looked inside the manuals, trying to find some special functions, that maybe will help you, but unfortunately i can't be specific; pls find attached infos about :
    ... coordinate system selection function
    ... tool center point function / tool attitude command
    ... the 3d coordinate conversion function
    ... tool posture compensation function / kindly
    Attached Files Attached Files
