586,102 active members*
2,477 visitors online*
    Jan 2012
    43
    Won't load new files
    Have a AWC708c controller using lasercad v7.96.
    Been having to erase any files in the controller in order to load a new file, small or large. Controller will show the file name as" unknown " and will not load any new files at all now.
    Been doing the manual reset at the controller after deleting all the current files but now that doesn't even work.
    To me it's a memory issue and preforming a reset is not clearing all
    the memory.
    Had a friend tell me a way to clear the memory but that was 2-3yrs ago and he as passed on now.
    Anyone know how to correct this problem?
    Rick
    Is there a photo available? I hope I can help you.
    Supply Forever Global Industry Co., Ltd.:https://www.supplyforever.com/
    Jan 2012
    43
    Re: Won't load new files
    Micheal
    not sure a pix of the controller would help. Controller just shows normal screen as when starting up.
    In the mean time I finally got the controller to take a SMALL file and was able to got to FILE then DELETE ALL FILES and that got it to take new files now. I only install one file at a time now, then do the "delete all files" to get me by till the proper solution is found.
    I know there is away to completely reset the system but have lost that info.
    Rick
  1. Bobcad V29 timeout. Won't load large files
    By kerm7807 in forum BobCad-Cam
    Last Post: 10-11-2018, 09:36 PM
  2. RFQ: Convert SolidWorks files to MDD files for Hanwha XE20
    By THPP in forum RFQ (Request for Quote)
    Last Post: 02-23-2017, 02:08 AM
  3. How to load files from Thumb Drive on Cent 6
    By Brian L in forum Milltronics
    Last Post: 06-05-2016, 03:52 PM
  4. Replies: 10
    Last Post: 04-12-2014, 04:03 PM
  5. Nubie...Autocad dxf files fail to load into lazycam
    By kansaswoodrat in forum Uncategorised CAM Discussion
    Last Post: 03-08-2014, 03:39 AM
