586,106 active members*
3,327 visitors online*
Results 1 to 11 of 11
    Dec 2014
    187
    Change CNC Controlbox
    I have a CNC that is self contained so doesn't need to be connected to a computer, I just add the file to cut onto a mini SD Card and put it into the Controlbox. I'm now wanting to connect directly to a computer so what recommendations does everyone have for the Power supply and controlbox replacement? Its 600x300 and 1500w Spindle
    Sep 2019
    197
    Re: Change CNC Controlbox
    Quote Originally Posted by KenR60 View Post
    Do you plan on upgrading your stepper drives too?
    Dec 2014
    187
    Quote Originally Posted by ericks View Post
    I wasn't planning too, the CNC has only done around 30 hours since new.
    Sep 2019
    197
    So you happy with the overall performance of the controls?
    Dec 2014
    187
    Was a lot of setting up and mucking around originally when I bought it, I haven't used it for around 2 years so I just want an easier system so I can control it directly
    Sep 2019
    197
    Okay, are you using mach3?
    Dec 2014
    187
    Happy to use anything, if I remember I couldn’t use mach3 because it wasn’t connected to a computer
    Sep 2019
    197
    Of course yes...
    Sep 2019
    197
    I use uc300eth on my machine with an Aussie made breakout board. Both work very well for me. The UC300 require a 5V psu and the bob a 12V. But there are many other options as people will most likely tell you.
    Sep 2019
    197
    Can you take a pic of inside the box, maybe you have enough space inside to do the mod
    May 2005
    3920
    I’m trying to determine your motivation here. There are so many options it is hard to say what is best. The first thing that comes to mind is this does the current controller support drip feed or other PC to controller communications. Is it does that would be the cheapest way to improve file handling.
  1. Change time delay in tool change program
    By bspear in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2018, 04:01 PM
  2. MicroSD Controlbox Reset Error
    By KenR60 in forum CNC Machine Related Electronics
    Last Post: 06-10-2016, 09:06 AM
  3. Replies: 6
    Last Post: 05-10-2016, 12:30 AM
  4. Replies: 2
    Last Post: 01-07-2014, 08:11 PM
  5. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
