586,115 active members*
3,304 visitors online*
    Jun 2008
    7
    Shop computer network issues
    Hi everyone. Been dealing with this issue for a while now and I'd like to get it resolved. In my shop I have two xp cnc systems running mach 3 and one win 7 computer that I use to do all my cad work and nc file creation. The win 7 system is connected to my win 10 home network. I want to share files! I want to be able to save my files to a location that I can access from my xp machines. I don't need to access the internet with the xp systems and networking xp to windows 10 is a pain! Right now I'm using a jump stick going back and forth. What is the best way to go about this? Thanks!
    Jan 2013
    630
    Re: Shop computer network issues
    Well...that's not too hard but you'll need to do a few things.
    1. You need to understand what you local subnet looks like. If you are using a consumer grade router it is likely handing out a class C subnet of IP address. Otherwise know as a /24 subnet. Most of these are similar in configuration out of the box so it is likely handing out some like 192.168.1.0/24 via DHCP. Its local address is almost always .1 unless it has been altered so that would put it at 192.168.1.1. You can ID that by opening a command prompt on your Windows machine and running ipconfig. It will spit back something like the following...
    Ethernet adapter vEthernet (Wireless Virtual Switch):
    Connection-specific DNS Suffix . :
    IPv4 Address. . . . . . . . . . . : 192.168.1.119
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.1.1
    The IPv4 address if the address of the machine you are running the command on.
    The subnet mask tells the machine which bits are subnet bits and which a host bits. We can get into that later as it is not terribly important to what you are doing.
    Default gateway will be the address of your router.
    Now letting the router hand out addressing works for most applications. However if you want to share a folder to be accessible to other machines it would be best to set a static IP address on the machine used to host the folder. So in the case of your CAD/CAM workstation you'd want to alter its configuration to be static. There are a couple ways to do that. One is to configure the router to reserve a specific address for that machine. If you want to go that route then you'll need to login to the router and verify that it supports DHCP address reservations. Some of them make it very easy and as simple as clicking a button on a clients configuration page in the router. Due to the need to keep the XP machines off the internet I think statically addressing the individual machines are going to be your best bet. The reason I say this is the best way to keep a machine off the internet is to just take away its default gateway. Easily accomplished via setting a static IP address.
    Windows XPStatic IP tutorial. ->
    Windows 7/10 static IP tutorial -> https://www.youtube.com/watch?v=5iRp1Nug0PU
    Once that is done and confirmed to be working you can move on the shared folder. The number one thing you'll need to do is make sure that each machine has an account with the same username and credentials. It doesn't have to be the account you use to login to the machine but that would make life easier. Whatever you do please do not use an account that is a local administrator. If you were to get an infection that would allow it to spread easily and infect the other machines.
    Windows 10 folder sharing turtorial. -> https://members.iracing.com/jforum/forums/list.page
    Please do not use the everyone permission as that leaves the share completely open to any machine that is allowed on your network. This should get you started and YouTube is your friend.
    Jan 2018
    1516
    I have exactly the same problems with this Microsoft garbage!!!
    From the 7 & 10 machines I can access the public folders on the XP ones but can't get it working in the other direction.
    All I do nowadays is save a copy of my Gcode files both locally and straight to the XP machines public documents folder ready to run.
    May 2015
    686
    By far the best solution is to install a NAS. I use a Synology and its still chugging away after about 10 years. QNAP is another brand but I have no experience.
    The whole Windows ecosystem is centred around you needing one of their server products to build your network.
    Rod Webster
    www.vehiclemods.net.au
    Jan 2013
    630
    I'll second the NAS as the easier solution but I gave direction based on the initial question.
  1. 2011 VF-3 how to connect to shop network
    By dfearnow in forum Haas Mills
    Last Post: 04-29-2013, 11:32 PM
  2. Replies: 1
    Last Post: 04-12-2013, 02:39 PM
  3. Mach 3 computer network
    By TOTALLYRC in forum Mach Software (ArtSoft software)
    Last Post: 11-20-2009, 05:12 AM
  4. Network issues
    By sunova in forum Haas Mills
    Last Post: 08-19-2009, 04:53 PM
  5. Citizen Swiss Network To Computer Help
    By SWISS20 in forum CNC Swiss Screw Machines
    Last Post: 02-19-2009, 08:40 PM
