586,060 active members*
4,279 visitors online*
    Nov 2017
    9
    Mach3 Turn/Lathe
    Hello,
    I would like to add a Y axis to Mach3 turn screen set. Anyone know if a screen set is available to add a third axis to Mach3 Turn? Thank you.
    Mar 2015
    17
    Re: Mach3 Turn/Lathe
    Relatively easy to add an extra axis using mach3screen.exe. nearly all you need is there already, you just need to add a couple of visual components like hero's.
    My not ended screenset. Made in Mach3 Screen for lathe with position spindle.
  1. Mach3 soft limit lathe Shopmaster Mill Turn
    By walters474 in forum Mach Lathe
    Last Post: 02-11-2019, 11:14 PM
  2. Homing MACH3 Turn (lathe)
    By itolond in forum Mach Lathe
    Last Post: 08-23-2017, 03:20 AM
  3. Replies: 15
    Last Post: 03-22-2016, 11:33 AM
  4. need help bobcad lathe mach3 turn
    By hanover owing in forum Mach Software (ArtSoft software)
    Last Post: 10-17-2012, 03:16 PM
  5. need help bobcad lathe mach3 turn threading
    By hanover owing in forum BobCad-Cam
    Last Post: 10-16-2012, 11:55 PM
