586,635 active members*
3,123 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Conduit for the X axis stepper motor
Results 1 to 10 of 10
    Jun 2014
    1780
    I was curious if anyone has come up with a replacement conduit for the X axis stepper motor? Mine is in bad shape and the coating is hard and peeling off, I cant see replacing it with the same as whats on there as its not holding up very well.
    thanks for any input
    mike sr
    Jun 2006
    3063
    Re: Conduit for the X axis stepper motor
    McMaster-Carr sells Liquid Tite conduit in various diameters and one of those should work. Grainger might also sell it if they are close enough to pickup.
    Jun 2014
    1780
    Quote Originally Posted by MichaelHenry View Post
    Thanks Mike, I was just wondering what others had done, This one has lasted almost 8 years, thats pretty good service life.
    mike sr
    Aug 2009
    230
    Well, it's not a Tormach, but for my Shizouka AN-S (really big CNC knee mill) I'm just using regular liquid-tight flex conduit I get at Lowe's or Home Depot.
    Jan 2007
    311
    ( I posted this in the wrong thread... twice...)
    After the problem I had with mine cracking for the x'th time I've been looking at different options, problem is how flexible the original stuff was and how stiff some of the other options are
    This "Type LNMP" or "Type LT" conduit but I'd like to physically touch a piece to see how flexible it is
    M
    15362
    Quote Originally Posted by popspipes View Post
    Does it do any movement, if so it has to have a flex rating, the liquid tite conduit they have suggested is no good if you have any flexing or axes movement
    This one is best if you have any movement there are many different suppliers for this PMA Conduit https://new.abb.com/low-voltage/prod...s/pma-conduits
    Here is a link for a PDF file http://tnblnx3.tnb.com/emAlbum/album...uitSystems.pdf
    Mactec54
    Jan 2007
    311
    The "Type LNMP" or "Type LT" ones I mentioned are both rated for continuous motion, oil resistant. One is metallic while the other is non (I think)
    I don't think either would be as floppy as the original (which has lasted a lot of years honestly) but being slightly stiffer wouldn't be a bad thing I believe
    M
    15362
    Quote Originally Posted by Mooser View Post
    M
    IF you have movement it won't last very long at all it is great for a static install so if you have any movement at all don't waste you time, always look at the application they list for the different types of conduit most you will see is for static installs for this type of conduit material type also plays a big part of the flex rating
    Mactec54
    Jan 2007
    311
    Type LNMP
    This UL and CSA listed nonmetallic liquidtight conduit is ideally suited for continuous flexing situations. It is often specified in “Power Track” or cable carrier installations and on industrial robots. It does not contain a metal core which could fatigue from repeated flexing or vibration.
    Flexible PVC
    Resistant to Oils and Mild Acids
    Flame Retardant
    Sunlight Resistant (UV)
    Type LT
    A general purpose flexible, oil-resistant, non-UL spec grade liquidtight steel conduit designed for a variety of installations requiring motion, vibration and bending. It offers good mechanical and moisture protection to enclosed conductors.Flexible PVC
    Flexible PVC
    Flame Retardant
    Liquidtight Oil Resistant
    M
    15362
    Type LNMP
    Flexible PVC
    Flame Retardant
    Type LT
    Flexible PVC
    Flame Retardant
    M
    You obvious have never used this, the LT you would never be use for any thing that has movement
    Only this one is suitable in the LNMP with a PVC outer and Nylon Inner
    Mactec54
  1. Replies: 8
    Last Post: 08-14-2017, 10:29 AM
  2. Calculations to find stepper motor for 5th axis. What motor?
    By dfaszer in forum Mechanical Calculations/Engineering Design
    Last Post: 12-01-2014, 10:53 PM
  3. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  4. 3 axis CNC controller kit 3 NEMA17 78 oz-in stepper motor + 3 axis CNC board
    By Chaparro1973 in forum Stepper Motors / Drives
    Last Post: 03-12-2012, 10:26 AM
