586,121 active members*
3,249 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > NM200 axes not moving
    Dec 2009
    594
    I went out to start up the mill today, and found that the PP control won't move the axes. Once the mill and PP are started, I can start the spindle, and jogging commands do cause the DROs to advance. I can manually turn the X-axis ball screw. No error messages. I checked all the cable and connections and all are secure. Mill was running fine before last shutdown.
    I thought I'd post here in case there was something obvious to check before I tear covers off the computers.
    If I disconnect the PP computer from the Novakon box and restore the loopback cable, I should be able to still run Mach3 on the CD100. I didn't feel up to that today.
    Dec 2013
    5717
    Re: NM200 axes not moving
    Fuse or breaker on the axis drive power supply?
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2009
    594
    Turns out one of the 3 power cords to the control had become detached. Easy fix.
    Dec 2013
    5717
    :cheers:
    Jim Dawson
    Sandy, Oregon, USA
  1. Moving across multiple axes at different speeds
    By p-teale in forum Linear and Rotary Motion
    Last Post: 09-16-2019, 03:10 AM
  2. when the Q2 axes is moving is jumping and vibrating
    By ceramdent in forum SIEMENS -> GENERAL
    Last Post: 10-03-2017, 08:51 PM
  3. Moving NM200 and Lathe to basement
    By azam1959 in forum Novakon
    Last Post: 02-19-2013, 03:47 PM
  4. Moving X & Y axes
    By Dubliner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-05-2010, 08:47 PM
  5. nm200 head moving/flexing under load
    By urbanimports02 in forum Novakon
    Last Post: 03-04-2010, 07:30 AM
