586,677 active members*
3,178 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan Lynx 220L lathe chuck issue
    Nov 2019
    Hi everyone,
    I'm getting a #2060 'CHUCK UNCLAMP STATUS' warning. The chuck opens and closes fine using the foot pedal but whether I try to start the spindle on manual or simply run the program this message appears.
    There was a similar question asked already but it seemed to be related to the actual opening/closing of the chuck...
    It's not a door interlock issue and I'm not trying to use a bar feeder. The program has been used recently on this machine so I dont think it could be a coding problem either.
    Any ideas much appreciated, thanks!
    Tom
    Feb 2013
    788
    If you have proximity switches on the back of your actuator then it is measuring over stroke and Chuck open. Either set the proximity switches correctly, or Chuck up on a part, or turn them off to bypass them.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Sep 2007
    66
    Re: Doosan Lynx 220L lathe chuck issue
    hi ,
    or turn the key for inside and outside clamping
    greeting bertus
  1. Doosan Lynx 210 LY
    By Green Button in forum Daewoo/Doosan
    Last Post: 08-31-2019, 12:12 PM
  2. Doosan 220 lynx issue...
    By enigma173 in forum Daewoo/Doosan
    Last Post: 06-25-2016, 11:52 AM
  3. Please Help Doosan Lynx 220 LM
    By norkis2006 in forum Daewoo/Doosan
    Last Post: 03-22-2014, 02:36 PM
  4. lynx doosan 220
    By tpsimer in forum MetalWork Discussion
    Last Post: 02-08-2014, 06:27 PM
