586,117 active members*
3,393 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Projecting lines
    Nov 2019
    Projecting lines
    Hi. I want to project the lines surrounding a body. I want them to be individual entities so that I can create a boundary around part of my model using one of the lines. When I project the geometry of a face using the geometry from solid tool using body/faces silhouette, it generates the full loop of the object, but as one entity, not as individual lines. If I use the copy from edges option, it does not let me do the actual projection. So I can't work out what to do. I have seen somebody else project the lines around a feature onto a 2d plane, so I know that it's possible. If anybody could help that would be amazing. Thank you.
    Attached Thumbnails Attached Thumbnails Geometry from solid.jpg   Geometry from solid 2.jpg
    Oct 2003
    127
    Re: Projecting lines
    not sure if this will work for what you want but when you generate the wire from solid, press the 2-D geometry button first and all the wire will be generated on a flat plane at your current Z level selection
