586,072 active members*
4,699 visitors online*
    Jun 2015
    13
    Choosing servos
    Hi, I am on my first cnc build and I need some explanation.
    To calculate size of servos I use https://www.orientalmotor.com/motor-...w-sizing.html# , but it gives me lower Nm numbers than I have read in over the internet. I am confused about acceleration/deceleration t1 value, don't know whats fast or slow?
    X axis
    150kg mass
    friction 0.1
    ballscrew 25mm, 1500mm, lead 5mm
    efficiency 90%
    material steel
    external force 100N
    no transmission, direct fit
    angle 0
    fixed speed 210mm/s
    acceleration/deceleration t1 0.2 ???
    safety factor 1.5
    It seems basically one 750w 2.39Nm is ok? I want to run on 2x X axis ballscrews and my gut feels minimum is 2x750W Servos. Does my values are wrong?
    24221
    Re: Choosing servos
    Kollmorgen also have a graphical sizing program, for different kinds of formats, Mills, lathes etc.
    Al.
    Albert E.
  1. Are Chinese servos a gamble? Servos vs Leadshine closed loop
    By j3dprints in forum Servo Motors / Drives
    Last Post: 01-05-2018, 07:09 AM
  2. Choosing the right Steppers/Servos and the right Control Software
    By twilliamson in forum DIY CNC Router Table Machines
    Last Post: 06-25-2017, 02:46 AM
  3. Choosing new used VMC
    By tfuqua63 in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2016, 06:21 PM
  4. Choosing servos and drivers
    By jharvey407 in forum Servo Motors / Drives
    Last Post: 05-11-2013, 02:59 PM
  5. Propriatary AC servos into universal AC servos with an encoder swap?
    By SwampDonkey in forum Servo Motors / Drives
    Last Post: 05-10-2013, 07:22 PM
