586,103 active members*
3,594 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Coil spring preloading a ballscrew
    Jul 2005
    107
    Hey all,
    I have a small pile of inexpensive THK MTF0802 ball screws. These guys have maybe 50 microns of axial play that I want to take out. Is it reasonable to use a coil spring to take it out? I need maybe 10-20 mm of travel, and my application requires relatively slow movement at a 100% duty cycle, and low loading... so relatively low forces across the board. I've never seen a ball screw preloaded with a coil spring... is this a reasonable thing to do?
    Dec 2013
    5717
    Re: Coil spring preloading a ballscrew
    My preference is an air spring, that way you get constant pressure through the entire range of movement. But if you can use a coil spring that is quite long relative to the needed movement, I think it should work fine. Loading won't be constant, but should be close enough.
    Jim Dawson
    Sandy, Oregon, USA
    15362
    Quote Originally Posted by sp1nm0nkey View Post
    Hey all,
    Yes some have used a spring but the more common is to use Belleville washers to take out the Backlash
    Mactec54
  1. Preloading of ballscrews without thread
    By joedesu1 in forum Linear and Rotary Motion
    Last Post: 01-06-2015, 02:46 AM
  2. Installing and Preloading Ballscrew??
    By iaknown in forum Uncategorised MetalWorking Machines
    Last Post: 10-07-2009, 04:11 PM
  3. Installing and Preloading Ballscrew???
    By iaknown in forum Linear and Rotary Motion
    Last Post: 10-03-2009, 03:25 AM
  4. Replies: 41
    Last Post: 01-13-2009, 06:29 PM
  5. Preloading
    By haku in forum DIY CNC Router Table Machines
    Last Post: 03-13-2008, 10:03 PM
