586,067 active members*
5,346 visitors online*
    Newbie help please
    I need help on motor setup, I’ve used a Electra beckum induction motor and switch gear, it’s a four wire 240v 2800rpm motor. Question it spins the wrong way, I could turn the motor round, but wanted a tight setup, also advice on type of speed controller, very eager to get advice so to get using it
    Apr 2004
    5737
    Re: Newbie help please
    I assume this is for the spindle, right? Some induction motors will reverse directions, others won't. To find out, remove the plate that covers the wire inputs. If it's reversible, there should be a diagram showing which wires to switch.
    Induction motors aren't susceptible to speed control; they run at fixed speeds, like 1725 or 3450 RPM. You can set up a pulley cluster to get different speeds, with torque multiplication as a bonus. If you want variable speed, either get a 3-phase motor and run it from a Variable Frequency Drive or a DC motor run through a PWM controller.
    Andrew Werby
    Website
    Thanks will check later and confirm the wiring, cheers
  1. Hello from a newbie
    By Clod in forum Australia, New Zealand Club House
    Last Post: 08-18-2008, 02:53 PM
  2. Newbie
    By cpworkshop in forum Australia, New Zealand Club House
    Last Post: 06-16-2008, 10:45 PM
