586,080 active members*
3,571 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > '91 Hurco BMC 20 Axis S Encoder Fault
    Dec 2019
    17
    Hello all,
    I have a '91 Hurco BMC 20 that decided to throw an "Axis S Encoder Fault" alarm on Monday. The machine will go through the power up/calibration process, but when I select "Warm Machine" it faults the spindle. Tuesday I came in and the machine went through the warm up process, spindle and all, but when I went to run a program the flood would not turn on. Turned off/on the machine and the "Axis S encoder Fault" came back up. Thanks in advance for any help. Dan
    Apr 2019
    58
    Re: '91 Hurco BMC 20 Axis S Encoder Fault
    Try to check i/o bords in pc it can behardware
    Išsi?sta naudojantis SM-G960F Tapatalk 4 Lt
    Dec 2019
    17
    Would I be looking for a loose connection?
    Apr 2019
    58
    Yes correct
    Or need to check for broken wires
  1. BMC 20 Encoder Fault Z Axis
    By ricochet in forum HURCO
    Last Post: 01-01-2014, 05:22 PM
  2. NEED HELP! Fault Code x-axis (HURCO VMX24)
    By wolfyy98 in forum HURCO
    Last Post: 01-03-2013, 01:56 PM
  3. Replies: 8
    Last Post: 09-09-2011, 02:01 PM
  4. hurco vm1 x axis fault
    By merv385 in forum HURCO
    Last Post: 11-23-2009, 09:20 PM
  5. X axis encoder fault/smoke
    By k4rd in forum HURCO
    Last Post: 10-02-2009, 12:15 AM
