586,058 active members*
3,425 visitors online*
    Sep 2003
    174
    NC look ahead
    VMX42 2011 model with Winmax control.
    I posted out some NC code to call up in the middle of a conversational program. The NC merge and industry standard NC options are on the control. It was a trochoidal toolpath and everything worked fine until it gets to a bit where the cutting and repositioning moves are small then it slows down. I'm using a modified Fanuc post from Onecnc without the G54 and G43. There's a look ahead line which is G5.1 Q1. This post works fine on a fanuc control. Am I missing something? Is there a different look ahead setting.
    Jun 2015
    4154
    Re: NC look ahead
    hy stevie, this should be normal : a cnc is never moving at a speed greater then the program value, thus real feed <= programed feed
    a toolpath is a serie of geometrical entities, and the machine will never show an alarm if entities length is too small for the nc to reach the programmed feed; in such a case, motion gets succumbed, but it should keep on going / kindly
    ps : imagine what would happen if an nc would stop when programmed feed is incorrect : an important fraction of active machines would suddenly breakdown however, you should be glad that you have noticed this behaviour, because it is the begining of a new path, that leads to a programing style that creates continous cnc motion; if you would work on an okuma machine, i would start to share you a few tricks; unfortunately, i can't help with tips for hurco, thus i don't know if hurco has methods to deal with this case
    Sep 2003
    174
    Re: NC look ahead
    Sorted it thanks. It was some settings in the Onecnc cam software that needed changing. In the post processor I had it set to output helical arc moves and the machine control mustn't like that. I also changed it to output arc moves as incremental I and J instead of just a radius and X Y end points. In the trochiodal toolpath when it repositions the Z lifts out of cut slightly and it does this helically. It now outputs a series of small lines and runs at full speed. A lot smoother too. Great.
  1. Look Ahead
    By Sit22 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 08-01-2011, 09:07 PM
  2. HSM and look-ahead
    By JohnJW in forum Haas Mills
    Last Post: 02-26-2010, 08:38 PM
  3. look ahead
    By cnc spook in forum Controller & Computer Solutions
    Last Post: 08-26-2009, 02:37 PM
  4. Look Ahead with G68
    By ludde_77 in forum Fanuc
    Last Post: 10-30-2008, 11:13 PM
  5. Oi-mc Look ahead
    By SIG in forum Fanuc
    Last Post: 10-03-2007, 04:36 AM
