586,106 active members*
3,125 visitors online*
Thread: Boundaries
    Dec 2019
    Boundaries
    I'm working on a contour cut of an island.
    The 3d model has boundaries within the final vector shape.
    The software Vectric V carve pro is cutting these boundaries within the vector shape.
    I want the model boundaries to not be cut.
    I cant figure out how to do this.
    Here is a pic , he oval is the final vector shape , you cabn see the 2 cuts at the extreme left/right of the oval.
    1227
    Re: Boundaries
    Have you tried moving those boundaries to a new layer and then turning that layer off before you click on calculate for a new toolpath? You could also use a third layer if you wanted to specify different boundaries.I like to use different colours for boundary or construction layers to save complications.
