586,036 active members*
4,388 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > ISO30 ER32 chuck question
    Nov 2012
    96
    I am looking to get a spare ISO30 chuck. My existing ones have smooth tapers with a groove. Some of the ones I'm looking at have a notch in the taper, pic attached. The spindle is an HSD 951. Could someone shed some light on the smooth taper vs notched alternatives.
    cuttingedgecnc.co.uk
    [email protected]
    Jun 2015
    4154
    Re: ISO30 ER32 chuck question
    hy, notch type is there to assure that the contact is done in both areas : upper and lower; this is a trick to avoid uneven contact, at least theoretical
    downside is that using a notch type for too long will generate a specific wear inside the spindle, and may lead to fly-out issues if a non-notch/classical toolholder is used
    i would gently advise you to stick with the cone types that you allready use; also, you may inspect your toolholders, especially the ones that you use most, so to have a clue about your current contact area; if it is not the same among different toolholders, then ... take a guess kindly
    ps1 : if you wish 4 something extra, then use nikken's 3point contact, with elastic taper, but this would be too much for a mere er32
    ps2 : bearing nuts ...
    Nov 2012
    96
    Sound advice, I have ordered more of the chucks I have. Thanks for the info.
    [email protected]
  1. Manufacturing dimensions for chuck collets ER32
    By CBR600 in forum Chucking and Measuring
    Last Post: 02-03-2020, 10:03 AM
  2. Need affordable iso30/er32 tool holders
    By comandojon in forum Commercial CNC Wood Routers
    Last Post: 06-12-2014, 05:28 PM
  3. ER32 collet chuck
    By bollero in forum Benchtop Machines
    Last Post: 08-30-2013, 04:08 AM
  4. Expected runout from an ER32 collet chuck
    By buckie555 in forum Uncategorised MetalWorking Machines
    Last Post: 04-01-2006, 02:32 PM
