586,069 active members*
3,831 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Error code E.L.u.n - during work with CNC
    Hello,
    Sorry for my bad English!
    I need help for my HY02D223B inverter
    During program execution, the inverter shows an E.L.u.n error and the spindle stops rotating.
    The problem does not have a clear recurrence, it can run for 2 minutes and manifest itself, and it can take 2 months without manifestation, under different cutting / punching loads.
    After the restart, everything starts anew, and the problem may or may not be repeated.
    I have had this machine for 5 years, but in the last one it started to make me this problem.
    I haven't changed a thing.
    Everything is set up by the manufacturer of my CNC.
    Re: Error code E.L.u.n - during work with CNC
    Buenos días nos pasa lo mismo con nuestra CNC, ¿podrías ayudarnos para saber cual es el problema?
    661218637
    Jun 2005
    1730
    That error is a low voltage input error. Check the voltage on your input lines, the VFD could also be dead due to some burned components
    15362
    Quote Originally Posted by mitakata_net View Post
    Hello,
    If it was set by the manufacture does not mean that it was set correctly.
    How is the input power wired to the VFD Drive, what Kw is your spindle motor
    You could also check your VFD drive to Spindle wiring this may have a bad connection.
    Mactec54
  1. Need Help - Amada RG 80 Error code 315 / Alarm code 315
    By P2CNC in forum Maintenance DIY Discussion
    Last Post: 04-18-2021, 06:58 PM
  2. Error codes for SCM Record 310 NT Router Error code 075-MACHINE OFF
    By GVANZ in forum Complaints and Praise Discussions
    Last Post: 05-28-2019, 08:30 AM
  3. Using g code on old router..WIll this code work?
    By graemeian in forum CNC Machining Centers
    Last Post: 04-19-2017, 11:34 PM
  4. Replies: 8
    Last Post: 02-06-2015, 03:56 PM
  5. g code error with image to g-code
    By cruzin in forum LinuxCNC (formerly EMC2)
    Last Post: 09-05-2012, 11:34 PM
