586,071 active members*
3,968 visitors online*
    Nov 2012
    96
    Sealing the vacuum bed
    I thought I would share this with other owners of machines with vacuum beds that include T track. I found we were losing a huge amount of vacuum (approx 5inHg) in the gaps between the vacuum beds and the T strips, and also at each end of the open T strips.
    I siliconed each side of the T strip where it meets the vacuum beds and machined some T track infills for each end. It has made a huge difference.
    cuttingedgecnc.co.uk
    [email protected]
    Jun 2015
    109
    Re: Sealing the vacuum bed
    Hi
    Yes I have had similar experience.
    When we filled in the gaps it was instantly noticeable the increase in suction.
    Contact me. I'm an engineer. I'll solve the problem for you. My name is sun. Usually in China, glass glue (neutral silicic acid) is applied around to increase the sealing performance. My WhatsUp ID + 8615621877020? If you have any questions, please contact me in time. Thank you
  1. Sealing cones
    By ORosti in forum MetalWork Discussion
    Last Post: 08-10-2018, 06:52 PM
  2. sealing a chuck against swarf
    By deadlykitten in forum Okuma
    Last Post: 10-10-2017, 02:54 PM
  3. 3 Part sealing?
    By pp-TG in forum Mechanical Calculations/Engineering Design
    Last Post: 02-28-2007, 02:41 AM
  4. Sealing MDF Structure
    By scratch_6057 in forum DIY CNC Router Table Machines
    Last Post: 06-30-2006, 05:13 PM
  5. Sealing a collet?
    By HuFlungDung in forum Uncategorised MetalWorking Machines
    Last Post: 04-13-2003, 11:36 PM
