586,110 active members*
3,354 visitors online*
Results 1 to 8 of 8
    Dec 2019
    Work Cnc Turning
    Hy i make Cnc programms for lathe.If somebody need my help i waiting pm.I worked like cnc operator on cnc lathe (fanuc) with automatically barfeeder.I work four years and half.Now i am engineering.
    Jan 2020
    Re: Work Cnc Turning
    How do you program taper on HAAS TL1? Can you use taper offset in tool offset page? Our machine has the IPS
    Dec 2005
    596
    Quote Originally Posted by 2020 View Post
    Perhaps if you ask your question in the Hass forum you might get a quicker answer?
    Jan 2020
    Quote Originally Posted by wendtmk View Post
    I am new to the site. Where is the HAAS forum located?
    Dec 2005
    596
    Take a look down in the MetalWorking Machines section.
    Jan 2019
    33
    Hi...im new in lathe machining. just bought a cnc lathe fanuc oi-tb with live tooling. i need to know which software will be worth learning. i have problem with activating live tooling as their spindles not moving . i need codes and your guidance.
    Jul 2020
    Precision CNC turned parts are a type of component that uses CNC lathes or CNC screw machines to process. Most of the part manufacturers have a wide ranging of material capabilities include stainless steel, carbon steel, aluminum brass, steel brass, titanium, and so on. And we make turned parts include drive shafts, interface fittings, shafts, flanges, nozzles, and housings. CNC turning centers use the rotational motion of the precision parts and the linear or curved motion of the cutting tool. They remove material, change the shape and size of the blank. And precision turned parts manufacturers then machine them to meet the requirements of the drawings.https://www.mlsmold.com/cnc-turning-...manufacturing/
    Aug 2020
    Hi~~Here is Ray Feng Machine Co., Ltd.
    We specialize in designing for electronic connectors, computer component, food processing machine, car, and hardware accessory, and so on. We always keep innovation, perfect quality, reasonable price and prompt delivery in mind to meet customers' needs.
    Our R & D team innovate new technology with reliable experience in this field for many years. Machines are suitable for processing small size workpieces with compound function. Especially, for turning, chamfering, drilling, tapping, and cutting off operation at one go.
    If you need any further information, please feel free to link our website.
    https://www.rfmcnc.com/en
    I hope it will help you to know more about the CNC .
