586,626 active members*
2,440 visitors online*
    Dec 2019
    Reci 100watt Laser Beam is Ring Shaped
    Hey folks.
    Just received a laser cutter Reci W2 and noticed that the beam coming out of the tube (before the 1st mirror) is ring shaped. The focused beam is not ring shaped though, but I presume lens would focus the ring to a point anyway. Question is though does the unfocused ring mean the tube is faulty somehow?
    Power supply is underpowered at 80watt. Could this be the cause? Also can under powered PSU cause any damage in the future to the Tube or PSU?
    Amazingly the lens in the laserhead was installed upside down. Is it also possibly that lens at the end of the tube could be the wrong way around? Does this come off does anyone know? I have cleaned but not attempted to remove it.
    thanks in advance for any answers
    Gil
    Quote Originally Posted by Eleusis View Post
    Hey folks.
    Gil
    I have this same problem this morning. Did you ever find a solution?
  1. Aligning mirrors, laser burn mark is ring shaped
    By enricosanchez in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-08-2017, 10:55 AM
  2. CO2 Laser Beam iis just an "O" Ring
    By nuniksais in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-12-2017, 11:11 AM
  3. Brand New RECI 100watt but very limited spark
    By KenR60 in forum Redsail Laser
    Last Post: 11-03-2016, 12:42 AM
  4. Reci tube Beam Adjustment
    By shizyo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2013, 04:10 AM
  5. Steel Ring Egg Shaped and Poor Finish
    By LaysMachinist in forum Material Machining Solutions
    Last Post: 03-01-2011, 07:32 PM
